Coming soon....Pre-book yours now!
For all your REVO software requirements
APR R1 Diverter Valve R1650
The APR R1 diverter valve was designed to be the ultimate solution to the problem of unreliable factory and aftermarket diverter valves and to be the leader in performance. Although most are of good design factory diverter valves are built in a very conscious manner and the materials and overall life and reliability suffer. For the performance enthusiast the diverter valve is an important component whose proper operation is paramount to optimal engine operation.
The R1 is designed for optimal performance. The main body of the valve is investment cast in an aluminum alloy. By utilizing this casting process in lieu of a more conventional machining process APR was able to optimize the internal geometry of the valve to provide the ultimate in flow performance. This geometry cannot be created utilizing conventional machining. As such the APR R1 has much better flow characteristics than other diverter valves. Combined with the low friction diaphragm assembly this equates to a valve that is truly a performance leader.
________________________________________________________________________________
APR Motorsport Turbo Inlet Hose-Blue - With FREE Clamp Kit
This hose replaces the existing hose and metal turbo intake combination and has a reinforced wall and super smooth internal design to ensure that laminar flow rates are maximized. With the original restrictions removed better flow characteristics are achieved which give noticeable gains in power and torque.
APR engineers designed a replacement hose of high quality silicone with wire wrapping throughout to ensure no collapse at even the highest boost pressures. We found that simply recreating the hoses in silicone no matter the density of the silicone still allowed a collapse to occur. The wire wrapping ensures that not even the slightest collapse will be experienced providing more air to the turbo via the larger diameter of the hose and smoother transitions unleashing hidden power.
ECS Gauge-N-Pod Kit R1500
Volkswagen Golf V 2.0T
Includes a NSP "Perfect Match Indigo Blue" Boost gauge, offset steering wheel mounted pod, and all necessary hardware
Complete gauge kit includes everything needed to install a boost gauge on your MK5 2.0T
MKV Steering wheel gauge pod
All Wiring & hose accesory specifically desgined for the Mk5 2.0T
No-Buzz T-Fitting specifcally designed for the 2.0T
NS Idigo perfect match boost gauge
Using the identical LEDs that light the Mk4/Mk5/B6/B7 Volkswagen instrument panel the Indigo™ gauges are a new cost-effective option for VW enthusiasts.
With details such as a lighted red needle a backlit black gauge face and lettering that matches the instrumentation the Indigo™ gauges will give you that factory look.
Pre-wired and complete with 6’ of nylon tubing connectors and fittings the Indigo™ boost gauge is an economic and simple solution for matching your Volkswagen instrumentation.
ECS Billet Aluminum Antenna "Sharan" Style - Black R150
68 mm long - machine finish
Machined billet aluminum antenna with machine finish. Fits 5mm and 6mm antenna bases.
*These sold out within 3 days on our last shipment!*
Magnetic Drain Plug With 10 Copper Washers R120
14x1.5, includes 10 copper seal washers
Magnetic Drain Plugs from ECS Tuning for your V/W & Audi. ECS MAGNETIC PLUGS have a permanent magnet that is fastened to the plug body. This magnet attracts and holds abrasive ferrous metal particles preventing their circulation through the lubrication or hydraulic system.
These abrasive ferrous metal particles appear in lubricating or hydraulic systems as a result of the following conditions:
The constant flaking effect of normal wear of moving parts.
Particles not removed by flushing operations after boring or machining.
Chipping due to sub-surface casting flaws.
Minute component breakdown caused by stress usage.
Usually a combination of factors accounts for the presence of these particles that cause excessive wear to vital components unless they are removed. By holding these particles ECS MAGNETIC DRAIN PLUGS prevent excessive wear to the system's components.
These drain plugs are to be torqued down to 22ft. lbs.
KJN
Re: Coming soon....Pre-book yours now!
Post by KJN »
1 ECS antenna for me please if pricing is similar to previous batch. Also postage to Durban.
PhatDub
Car Make: Audi, Volkswagen
Car Model: 2004 Avant 1.9TDi, Golf 4 1.6
Post by PhatDub »
is that TIP for AEB fitment and is that a 1.8T diverter valve, pricing?
"We ride together, we die together...Bad Boys for life"
PhatDub Waa'ntjie
PhatMom Vehicle
1.6carbster
Registered for: 19 years 3 months
Car Model: 330i (E90)
Post by 1.6carbster »
you've got my order, hey Shaunie? :hi: or must i reply in this thread too? :???:
2005 BMW 330i (E90) The Beef
1999 Audi A4 1.8T (AEB) the tank
1992 VW Citi 1.8i MP9 R.I.P.
1973 Mini Cooper S sold
EX-DOHCTOR
Registered for: 20 years 7 months
Membership No: 712
Post by EX-DOHCTOR »
Price indication might be helpful :grin:
Polo05
Membership No: 1271
Post by Polo05 »
KJN wrote:1 ECS antenna for me please if pricing is similar to previous batch. Also postage to Durban.
X2 KJN and i can share the postage costs if that's cool with him.
8v RS3 Sportback
1990 MK1 Cabriolet
2015 MK 7 .:R
2005 Polo Hatch
1984 MK1 GX - Bagged
2013 MK 7 GTI DSG
Golf 4 V6 4motion
1982 Mk1 GTS
2007 Golf 5 GTI - K04
*ace*
Registered for: 19 years 5 months
Membership No: 1024
Post by *ace* »
Im in durbs on the 27th bru, ill bring it down for yall ;)
Ill even fit it to storm to test it on the way down :geek:
ugan
Pricing on the antenna is the same as before.
Will update the thread with pricing on the NSP pod, Magnetic drain plugs and the R1 DV as soon as they arrive.
The 1.8T TIP is SOLD.
KJN
Post by KJN »
No probs bro. I am in central Durban everyday and live in Queensburgh.
1.6carbster
Rabbit222 wrote:Pricing on the antenna is the same as before.
:wink:
Polo05
Membership No: 1271
Post by Polo05 »
Mooloo, please mail me banking details.
KJN, i live in Queensburgh as well, *ace* will bring it down for us and we can meet up in the district to pickup yours.
Thanks Ugs :grin:
8v RS3 Sportback
1990 MK1 Cabriolet
2015 MK 7 .:R
2005 Polo Hatch
2013 MK 7 GTI DSG
Golf 4 V6 4motion
1982 Mk1 GTS
KJN
Post by KJN »
Thanks Ugs :grin:
Small world :hi: Cool bro. :cool:
GTIV
Registered for: 17 years 7 months
Post by GTIV »
Mr. Mooloo Please send two attenna for me thanks.
Mail me price an banking details thanks
Riaz Junaid
082 663 6996
Riaz@Stealthtuned.co.za
2011 G6 GTI DSG
12.3 @ 182kph
2007 GOLF GTI -13.2
RIP KIENAN
GTIV wrote:Mr. Mooloo Please send two attenna for me thanks.
Ok, best plan here is I'm gonna send all the antennas to one central point and you can distribute them?
*ace*
Membership No: 1024
Post by *ace* »
Gimme all 4 bokkie. Ill take em down. If i dont meet up with Riaz, Mag's will drop it off with him.
ugan
Stuff hasn't shipped out yet. If its here by then, I will gladly give it to you boet....
Awesum
Car Model: Tiguan
Membership No: 999
Post by Awesum »
I'm also going down towards the end of December.
If its still around I can take it down 4 u.
2019 Tiguan 2.0TDI, R-Line
2019 Polo GTI
Ex 2013 Tiguan 2.0TDI
Ex 2016 Golf VII R, DSG
Ex 2015 Polo 6C GTI, DSG, Pure White
Ex 2014 Golf VII GTI, DSG, Tornado red
Ex 2010 Scirocco 2.0TSi, DSG; Candy White; Revo, 20" RS6 wheels; Coiled looow.
Ex 2010 Golf VI GTI Dsg, Tornado Red, 19's, Revo 2
Ex 2008 Golf V GTI DSG, Riding on 19"s
Ex 2007 Golf V GTI DSG
Ex 2002 Golf IV GTI
Ex 1991 Golf II GTi 2.0 16V
Ex 1991 Jetta II CLi 1.8 8V Exec
devZo
Car Model: Polo TSI
Membership No: 1395
Post by devZo »
Mr. Mooloo, Please send me price & banking details, also want one of those aerials...
Polo TSI Highline DSG
ex:Polo TSI Comfortline
ex:MKVII GTI DSG
ex:MKVI GTI DSG CPi Tuned
ex:MKV GTI CPi Tuned
ex:Polo TDI Sportline
ex:VeloCiti 1.4i
Ex-Rides Thread
Ok dudes, I need you to slap your name down in this thread so that I can keep track of how many antennas are pre-booked. Judging from the response I may need to increase my order qty!
KJN
Post by KJN »
Ok I will start a list for the antennas
KJN
Polo05
devZo
Zaheer
Farhaad
Stuart
Scott
Dood
Team TDI
Car Make: Alfa Romeo
Car Model: Giulietta QV
Post by Team TDI »
KJN wrote:Ok I will start a list for the antennas
KJN
Polo05
devZo
Zaheer
Farhaad
Stuart
Scott
Dood
Don't know if that's me or not, but i did email you. And i definitely want one
Rides:
VW Polo TDI Sportline
Alfa Romeo Giulietta QV
pioneer
Registered for: 16 years 5 months
Post by pioneer »
I pmed u... want an antenna please.
List continued..
KJN wrote:
KJN
Polo05
devZo
Zaheer
Farhaad
Stuart
Scott
Dood
Pioneer
KJN
Polo05
devZo
Zaheer
Farhaad
Stuart
Scott
Dood
Thats you Mr Roux, I added your name to the list based on the emails I received.
Team TDI
Post by Team TDI »
Rabbit222 wrote:
KJN
Polo05
devZo
Zaheer
Farhaad
Stuart
Scott
Dood
Ok cool, thanks
Rides:
pioneer
Post by pioneer »
Updated list:
KJN
Polo05
devZo
Zaheer
Farhaad
Stuart
Scott
Dood
Pioneer
