braided fuel hoses in Cti
kevincti
Registered for: 18 years 10 months
Post by kevincti »
can antone tell me where i can get these fuel lines that lead from the fuel distributor to the injectors replaced. im in kzn
LittleG
Registered for: 22 years 9 months
Re: braided fuel hoses in Cti
Post by LittleG »
kevincti wrote:can antone tell me where i can get these fuel lines that lead from the fuel distributor to the injectors replaced. im in kzn
Send VWF KevinGTi a PM he had a few spares for the Kjet stuff and he is in KZN he should be able to point you in the right direction.
The CTI and GTI had the fuel distributer in different locations so not sure if you can use MK2 stuff on the MK1 but you might be able too. But one thing to note is there are two types on the MK2 there is the coarse thread and the fine thread one's. The side by the fuel distributer is the same and will work on any distributer but they different on the injector side where they screw to tighten so make sure the the same :wink:
kevincti
Post by kevincti »
thanks i appreciate the advice
