EDC15 Switchable Maps
Jabu27
Registered for: 4 months
Post by Jabu27 »
Hi Guys,
Is there anyone in SA doing a switchable Map setup for an ASZ Polo?
The reason I ask, I want to run a eco 'low smoke map for daily driving' and an aggressive map for racing.
Alternatively, I have a spare decoded ecu, and I could 3D print a dual ECU bracket and do some wiring magic to switch between ECU's loaded with different maps..
Thought it might be over kill to go this route if there is a viable solution in the market.
07' Polo Sportline TDI - GTB 2260; Veicomer 272; 120 Injectors; ARP bolts everywhere 8)
Ashveer03
Re: EDC15 Switchable Maps
Post by Ashveer03 »
Toxic tuning does map switching on edc15 and I'm sure many other tuners also do it. Tuners came about with that a long long time ago.
Map switching is a waste of time in my opinion unless u have nitrous. Why just not drive slowly when U feel like it? What mods do U have?
If U would be kind enough to share your ideas on your wiring magic, because the only way I see that happening is by physically swapping the harnesses between the 2 ecus.
Jabu27
Post by Jabu27 »
Hi Ashveer,
Thanks for the reply bud.
This is good to know, I couldn't find any info online of this being done locally.
In terms of wiring, I would splice all the ecu cables and feed both ecus, with a toggle switch between the main power connection.
Main Power Mods:
Gtb2260
272 cam
120% Injectors
FMIC
CAI
Straight exhaust
Ashveer03
Post by Ashveer03 »
The ecus are not gonna like being spliced considering they work with very small voltages and currents, the voltage drops and back feeding are gonna cause issues.
Anyways good luck, U have some decent mods
Jabu27
Post by Jabu27 »
Thanks for the advice Ashveer.
I will refrain from going the dual ecu route.
Best Regards
Jabu27
