Citi Golf Tenaciti 2006 power loss.
carburetooooooor
Registered for: 4 months
Post by carburetooooooor »
Hello, :geek:
I wanted ask for some help diagnoising a problem with my citi golf.
At some point in the past the car power cut out while i was driving in heavy rain.
Yesterday it was raining heavily and whilst driving the accelorator cut. Hevay reain = common denominator.
It would pop and choke and the rumble of the engine would become more inconsistent in sound and tempo and then cut out. If i waited a bit it would start up again, but it would for a while struggle to start again, ignition would work but the accelerator would peter out :cry:
Is this just a thing i can expect to happen in heavy rain or might it be a deeper issue?
Thank you.
marzbars
Car Model: 1988 Corrado 16V
Membership No: 1316
Re: Citi Golf Tenaciti 2006 power loss.
Post by marzbars »
Sounds like your sparkplugs are getting wet, they beauty of u-flow heads and the plugs facing the grill.
Try use some Q20 to disperse the rainwater
Preggz
Registered for: 11 years 9 months
Car Model: 06 Velociti & 13 6r PGti
Post by Preggz »
carburetooooooor wrote: Mon Feb 03, 2025 12:22 pm Hello, :geek:
Thank you.
Hey Bud
it seems it could be the coil i had the similar problem with my 2005 Velociti
LöW Ridër Velociti
JOMs FTW
Reflex Sliver Polo 6R GTI
HnR Springs
Dp
Forge Intake
SW (Dark Arts)
carburetooooooor
marzbars wrote: Mon Feb 03, 2025 12:48 pm Sounds like your sparkplugs are getting wet, they beauty of u-flow heads and the plugs facing the grill.
Thanks will clean the spark plugs and then see.
carburetooooooor
Preggz wrote: Mon Feb 03, 2025 2:52 pm
Hey Bud
Thanks for responding. Ill check the coils,
carburetooooooor
Thank you.
Hey Bud
Hey, the coil seems to be the problem. Its causinig an arc. i want to remove it and clean it but its tricky. Do you have any adviice for removing allen bolts? 4mm?
