Mr turbo wiring loom
- Registered for: 4 years 4 months
I need some help on the Mr turbo V1.7 efi silver box wiring loom. I connected everything according to the Mr turbo V1.7 wiring diagram I got of their website. The problem I got is the 4 wires that go to the relay on the loom. The way I connected the relay as follows pin30 - positive from battery, pin86 - no 7 +ve wire from the connector of the loom from efi box, pin85 - no3 earth wire from the connector of the loom from efi box,pin87- no +ve15 wire which is joined which positive wire for injectors. For checking and precaution sake I installed a fuse between the positive from battery to relay. When I turn ignition on it blows the 30amp fuse. When I swop pin86 with pin87 it blows the fuel pump fuse. Please advise.
- Neuk
- Treasurer
- Membership No: 806
Re: Mr turbo wiring loom
Welcome and enjoy the forum
