Hi All
After selling my Jumbo MK2 I moved on with life bought other brands etc and ended up getting me a 1984 Golf mk1 Automatic
It is a 1.5 Carb auto 3speed
im having difficulty on getting the idle in P and N to stay low
Is there anyone on the platform that owns one orhas any knowledge on how do i set it as i tried setting at the distributor but it cuts off or revs high still
1984 Golf mk1 Auto Questions
- Car Model: MK2 CSL
- marzbars
- Car Model: 1988 Corrado 16V
- Membership No: 1316
Re: 1984 Golf mk1 Auto Questions
010 box. Had one in my 1984 Jetta GLS, see rides thread in my signature.
They are lazy little lards, but the guys in the states modify these for drag racing by changing one of the shafts.
Could be that the carb has an "aftermarket" air control valve, found in the GW service kits, these are inferrior to the original VW air screw.
Potenital leaks in the base plate as well, just make sure when you buy a replacement, that it has the same bracket for the kickdown cable to the box
Current : 1988 VW Corrado
Ex : 1990 VW Golf CSL 1.6
Ex : 1995 VW Caddy 2.0 8v
Ex : 1996 VW Golf 3 GTS 1.8i
Ex : 1995 VW Golf 3 GTI
Ex : 1993 VW Chico 1.3
Hi Marzbarsmarzbars wrote: ↑Mon Jan 29, 2024 12:22 pm 010 box. Had one in my 1984 Jetta GLS, see rides thread in my signature.
Thank you for your response
Your response answers quite a bit as my bro in law for some reason though the carb that the car had was dead so he took one off a Caddy bakkie and ever since its acting up-
Last night i played with the distributor which made it idle a bit better but today when driving consumption went up now
my base plate is new i even sprayed carb cleaner to see if it stalls or picks up revs but nothing
The braker booster vacuums are not in place and the distributor doesnt have the advance on it with that pipe running to the carb somewhere
i fiddled witht he air screw i think (the flat screw just below the accel cable) that did help also with the idle but fuel consumption goes up
do you maybe know what other boxes with more gears will fit this would be so much better on keeping the stock engine
What do u mean by the brake booster vacuums are not in place?
If they are disconnected, that's a vacuum leak - it will cause idle issues.
The flat screw beneath the accel cable should be the idle screw.
- marzbars
Manual carb will not work on an automatic
https://vwclub.co.za/forum/viewtopic.ph ... 0&start=75
Rather get the carb serviced that was in there
brake booster vacuums have plugs on it to block it -
the one that was on it got put on the caddy and sold so im stuck with the one thats on itmarzbars wrote: ↑Wed Jan 31, 2024 11:35 am Manual carb will not work on an automatic
What's the idle difference between P/N and D/R?
