Hi Guys
I'm currently adding a amp and 2 X 12 dvc subwoofers to my citi golf
I currently have bullet super tweeters and super tweeters on all doors
Front doors has splits and back board has 6x9s
I'm currently running it on standard battery and alternator , will changing my battery to a 652 run my new additions safely ?
The specs are as follows Powerbass dvc 12" 24000watts 1500rms X 2 and a targa street falcon 7kd 3500rms
Thanking each of you in advance
2008 Golf mk1 Citi golf 1.4i
- Registered for: 2 years 5 months
- Ritz-ZN
- Car Make: Polo
- Car Model: Citi 1.4
Re: 2008 Golf mk1 Citi golf 1.4i
Hi budd
RE "I'm currently running it on standard battery and alternator , will changing my battery to a 652 run my new additions safely ?"
A bigger battery will help but only if its backed up by a good alternator. Your model should be using a 55/65A/h alternator and the normal 652's are rated higher. so your battery will always drain before your alternator can provide a "good" charge. Ideally you would want to do the Alti and battery upgrade together. Or if you have the money invest in a Targa battery(Veeeery expensive though-but in the long run its worth it).
I hope this helps. I been through the exact same issue with my setup
Cheers budd
Cheers budd
05 Citi Golf 1.4
11 Vivo Sedan 1.4i
04 Polo Comfortline 1.6i
78 MK1 Gts
Toyo 20v
Toyo 180i Sprinter
Gli Twincam
11 Vivo Sedan 1.4i
78 MK1 Gts
Toyo 20v
Toyo 180i Sprinter
Gli Twincam
TheShinagami1606 wrote: ↑Mon Jan 23, 2023 6:24 pm Hi Guys
here i would say
firstly if you gone run the car audio while driving( I would advise this) or standing still with the battery off( Iwould not advise this)?
if you gone be partying with the car from time to time lets say 1nc every 6 months while the car is idling its ok but not excessive playing.
Your battery cannot take the current draw even while driving .
First off invest in a big 3 upgrade Either youtube it or get a pro to do this.
If you invest in proper spec box your subs will be more effecient and loud with lower amp volumes ( Also great sound from a citi golf ). Most current amp draw will be from the mono.
628 for me normal life span is 3 to 4 years . With sound if u make sure to always check and play while driving its 2 to 2.5 years.
652 is better yes but do big 3 upgrade
If you really have the money
targa batt yes
or optima which im sure is more expensive
option 3 628 infront and second at the back plus bigger alti.
i see this is a old post so i dont see us getting a reply on how it worked out.
