Low oil pressure polo
RPG
Post by RPG »
Hi need some advice hope you will be able to assist, my polo bah recently start having low oil pressure I bought a mechanical gauge and it showed roughly 2 bar on cold and went down to. 5 as it started heating up so I changed the oil pump but results stayed the same then I tooked everything apart send in the crank and head to the engeneering to have it redone no visible signs that would indicate a cause, there is now new bearings pistons, rings, Vale lifters in but still have the low oil pressure issue if you can give any advice I would appreciate it
