Water disappearing
Water disappearing
I have a challenge of water disappearing and I did find the problem to be a top gasket which I repaired 3 weeks ago. And it has started again. And I did check the deep stick and yes it is that the top gasket is messed up again. Now it will be unwise to just fix it without knowing the cause leading to that. May someone kindly give me some light as to what might be the cause of all this. Thank you.
Re: Water disappearing
What car do you drive?Wartext wrote:I have a challenge of water disappearing and I did find the problem to be a top gasket which I repaired 3 weeks ago. And it has started again. And I did check the deep stick and yes it is that the top gasket is messed up again. Now it will be unwise to just fix it without knowing the cause leading to that. May someone kindly give me some light as to what might be the cause of all this. Thank you.
I smell school fees.
