My mk1 golf need some advise on technical stuff
Sorry to just jump right in on the page but have some qs for you guys I have a mk1 golf with 2e sub and a3 1.8 20v head gt35 turbo, spiral cut stainless steel valves with double valve springs, head is port and polished, running 1.8 conrods with 83 mm pistons that is machined and pocket for valve clearance and for the perfect 10:1 compression ratio, my q is can I run 2 shots of nitrous and 1 shot of water methonal injection with my injectors and will the motor handle it or do I need to do extra work?
- Car Make: Merc
- Car Model: C63 Edition 507
Re: My mk1 golf need some advise on technical stuff
10:1 compression seems high for that kind of turbo setup - usualy only motors running direct injection have higher compression turbo setups and then they tend to run smaller turbos. Anyow I'm sure Panic might be able to answer you
Polo 20VBigT - The Redhead
C63 507 Edition - The Dragon
Isuzu 4x4 - Little Joe
At 8.5:1 compression ratio yes to all of the above.Grim mk1 wrote:Sorry to just jump right in on the page but have some qs for you guys I have a mk1 golf with 2e sub and a3 1.8 20v head gt35 turbo, spiral cut stainless steel valves with double valve springs, head is port and polished, running 1.8 conrods with 83 mm pistons that is machined and pocket for valve clearance and for the perfect 10:1 compression ratio, my q is can I run 2 shots of nitrous and 1 shot of water methonal injection with my injectors and will the motor handle it or do I need to do extra work?
10:1 compression? I will pay money to see it blow up when it revs up for the first time. It will be spectacular.
