Polo 9n3 GTi clutch issues...
Keshan_G
Car Model: Polo 9n3 GTi
Post by Keshan_G » Fri Aug 16, 2019 2:42 pm
Hi guys,
I need some help,
I installed a motor in my car, after the test drive I found that the clutch would slip when in boost.
So we dropped the box, skimmed the flywheel and changed the clutch (smf set up).
The problem was still the same, the clutch would slip when coming into boost, the clutch pedal got rock hard and when I applied pressure to it, the master cylinder popped.
I have changed the master cylinder, changed the slave cylinder and changed the release fork but the problem still remains..
Any idea what could be causing this?
Thank you
'07 Blue Polo GTi 9n3
Powerflow 76mm DP- 63mm Zorst> 90deg intage/cone> Forge TIP> Forge Splitter DV> Forge Charge Pipe> Cupra FMIC> BC Coilies> R8 Coilpacks> 4Bar FPR > Devils Own Stage2 WMI
