ABF Turbo with cams?
PapaJo
Registered for: 14 years
Car Make: VW's
Re: ABF Turbo with cams?
Post by PapaJo »
Von 2e wrote: Sat Apr 27, 2019 6:12 am
PapaJo wrote:Expensive mistakes. School fees. Better luck next time.
ImageYea but I probably have to learn somehow... I hope you could help me. I know theres plenty to it but on turbo size? At wich A/R hot side size would i look at for a 2 l? Would A/R. 82 be to big?
Sent from my SM-N950F using Tapatalk
What is your goal? I know you said 300kw, but???
Drag car?
Daily that can kick butt robot to robot?
Quarter mile ripper?
1km sprint ripper?
In short:::
Bigger A/R more turbo lag and flow more exhaust gas at high rpm.
Lower A/R less turbo lag lower in rpm range, but sacrifice top end power.
Von 2e
Post by Von 2e »
Drag car?
1km sprint ripper?
In short:::
Tbought I would be happy with a strong street golf but seems im going a bit of course with that ideaImage. I want a setup that would tear up the 1/4 mile strip. Looking at doing good times. Would a 2l have enough to spool up a 82 housing? I know there would be some lag but if I install the rev kit I could manage to keep it in the power range or am I wrong?
Killerwatt
Car Model: S3
Post by Killerwatt »
Still depends on what turbine you want to use in there as well.
Really think you need to narrow down what you want out of this buld or just build something and refine it from there.
PapaJo
Car Make: VW's
Post by PapaJo »
Agree with Killerwatt.
Think you should then rather consider a setup with .48 t3 hot side in the turbo range of a gt28 (disco potato) or gt30 (gt3071) turbo group that could fit in on your possible performance expected goal.
Von 2e
Post by Von 2e »
Thanks for all the replys I appreciate it. Like I said im not a mechanic but would like to build it on my own. So I really appreciate all the info I can get. Sounds rather good what you suggest. If I could get it going and work from there I could know whats needed where. Thanks again for the replys
