My VW Golf 1.4i
My VW Golf 1.4i
My VW Golf 1.4i citi won't start after I left it in the rain. Someone just told me to check the two relays underneath the dashboard.
- Dub rox
- Car Model: Citi sport 1.4i
Re: My VW Golf 1.4i
Also check the fuses by the battery, coil pack and inside the dizzy for moisture.Citi Golf 1.4 wrote:My VW Golf 1.4i citi won't start after I left it in the rain. Someone just told me to check the two relays underneath the dashboard.
Coil packs sometimes crack when hot and get whet.
- Dub rox
Re: My VW Golf 1.4i
Depends if you were driving in the rain or car just got soaked??Dub rox wrote:Also check the fuses by the battery, coil pack and inside the dizzy for moisture.Citi Golf 1.4 wrote:My VW Golf 1.4i citi won't start after I left it in the rain. Someone just told me to check the two relays underneath the dashboard.
Re: My VW Golf 1.4i
It just got soaked while parked outside
- Dub rox
Re: My VW Golf 1.4i
Check the fuse box for blown fuses and trace it back to the soarce. Could be an electrical short somewhere. Also the two big fuses by the battery.Citi Golf 1.4 wrote:It just got soaked while parked outside
Does the engine turn over when you crank it?
- Dub rox
Re: My VW Golf 1.4i
Did you get it sorted @ Citi Golf 1.4 ?Citi Golf 1.4 wrote:My VW Golf 1.4i citi won't start after I left it in the rain. Someone just told me to check the two relays underneath the dashboard.
