VW Polo 1.9tdi purchase advice
PlayaSwaggin
Registered for: 8 years 5 months
Car Model: Polo Playa
Post by PlayaSwaggin »
Hi Gents,
i would like to purchase a 2006 VW polo 1.9 TDI Comfortline.
Any one with some advise on this car. it has abt 170k kms
dont want to spend on this car in future.
worried about turbo packing up? risk ?
any advice on this cars?
thanks
MarshallGTi
Registered for: 14 years 3 months
Car Model: Ibiza 1.9TDi FR
Membership No: 1665
Re: VW Polo 1.9tdi purchase advice
Post by MarshallGTi »
If its on the recall turbo already, you should be good, if it still has the stock turbo its a matter of WHEN it will pop, not IF it will pop. BV39 turbo still cheap at the dealerships, paid R7350 in the beginning of the year.
Have someone run logs on it, especially the injector values, at that mileage they could start going bad and they are expensive. If its the original clutch it will be near the end of its life. Check when last the cambelt and water pump were changed. If you take it, service it with correct oil straight away. If you can, pop the cam cover off and look at the lifters and cam lobe condition.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
billionairebum
Registered for: 10 years 6 months
Car Model: Sportline
Membership No: 3194
Post by billionairebum »
The comfortline uses a 74kw turbo not a 96kw turbo, 5 speed vs 6 speed. If you keep the car stock and drive it very nicely then it should be ok. The 74kw turbos do not like any mods and are not as reliable as the 96kw. I had the Comfortline(74kw) for 6 years and 320 000km without any real issues. Price of the turbo has gone up a lot to around R9500-ish.
Ashveer03
Post by Ashveer03 »
The 74kw KP39 turbo runs well when stock. I have seen a few of them run well over 300k kms untouched.
Infact im gonna be upgrading one of those cars turbos next week (cross polo), keen to see the condition of the original turbo
dhirennaidoo
Registered for: 18 years 9 months
Car Model: 9n Polo Classic TDi (PD100)
Post by dhirennaidoo »
My 74kW turbo ran fine for about 230 000km. I replaced it with a 96kW turbo at that mileage and am now doing 260 000km. The original turbo was fine, I just replaced for tinkering purposes. Furthermore, that original turbo ran slightly higher boost (1.2 bar) from about 45 000km till its removal so I would say mine was perfectly reliable.
The car in general been quite reliable, with me replacing the following items I consider not normal wear-and-tear:
LCA bushes @ 65 000 km (replaced them with Golf 5 bushes and haven't had to replace since)
Fuel filler lock solenoid
Brake pedal switch
Alternator pulley (it has a one way mechanism which failed)
Clutch & DMF @ 160 000km (some say this is normal for a TDi)
The following normal wear & tear:
CV joints @ about 230 000km (I consider this normal because I wasn't the kindest to them)
Shocks @ 240 000km
Dogbone mount
Engine mounts
Did snap an OEM cambelt around 250 000km, but that was probably to do with popcorn limiters :bang:
'08 350Z
'05 Polo Classic TDi (PD100)
Ex : '12 Mk6 GTi Ed35, '91 Fox 1.8, Honda CBR600F, '09 Honda CBX250 Twister
Trishen94
Registered for: 6 years 8 months
Car Model: Mk5 gti
Post by Trishen94 »
I had the 96kw sportline and trust me it's the best car I've ever owned I sold it 3 months ago and really regret it. im now driving a mk5 gti it's really exciting also don't plan on selling this 1 soon... but that polo was awesome I really miss it actually planning on buying another 1 soon ...as the guys say maintain it properly and respect it and u will have no issues the fuel consumption is amazing I actually used to forget to fill fuel sometimes coz it was so light ...just do a decat on it coz th3 diesel vehicle blocks the cat very fast and service regularly the guys have already told u to check the turbo and clutch other than that I good to go
viewtopic.php?f=11&t=217296
Previous :too many to list
