Noise over speakers when engine running.
Posted: Mon Aug 06, 2018 8:53 pm
by mellos
Hi there,I am experiencing some interference over my speakers when the engine is running.
I was having problems with the head unit switching off from time to time so I decided to power up directly
from the battery with an in line fuse but after that there was no more switching off but this engine
sound interference,could it be that maybe this power cable is too close to the cables running to
the amplifier,I want to remove the head unit but just looking for some advice so when I remove
it I know what or where to look for a solution.
Thanks.....
Re: Noise over speakers when engine running.
Posted: Tue Aug 07, 2018 8:06 am
by TDIFlava
Grounding issue and power cables running to close to your RCA's, make sure the head unit is grounded properly as well.
Posted: Tue Aug 07, 2018 8:13 am
by amstel18
RCA's and power cable on the same side of the car?
I always run the power cable on the side where the main wiring harness is and the RCA's either down the center or on the opposite side.
If they are already separated, then what Headunit is in the car?
I once had to ground the outer of the RCA's to the headunit. It was a JVC deck.
Posted: Tue Aug 07, 2018 10:21 am
by DJ7
TDIFlava wrote: ↑Tue Aug 07, 2018 8:06 am
More than likely this. Even more likely if it is a Pioneer HU. Cable from the back of the HU to the body to ground it should help.
Posted: Tue Aug 07, 2018 11:47 am
by Wolf Mk2 16V
In a Mk7 Gti they call it a soundactuator
Posted: Tue Aug 07, 2018 11:59 am
by Jetta2
Wolf Mk2 16V wrote: ↑Tue Aug 07, 2018 11:47 am
Actually called Soundaktor.
Posted: Tue Aug 07, 2018 12:34 pm
by Wolf Mk2 16V
Jetta2 wrote: ↑Tue Aug 07, 2018 11:59 am
I thought so but wasn't sure hehehe anyway soundaktor - mine is disconnected btw - huge improvement
Posted: Tue Aug 07, 2018 10:50 pm
by mellos
DJ7 wrote: ↑Tue Aug 07, 2018 10:21 am
It is a Pioneer head unit,why do they need a more solid grounding than other HU?
Posted: Tue Aug 07, 2018 10:55 pm
by mellos
amstel18 wrote: ↑Tue Aug 07, 2018 8:13 am
It is a pioneer HU,they are separated,I don't understand what you mean by "ground the outer of the RCA'S to the head unit?'
Posted: Tue Aug 07, 2018 10:57 pm
by mellos
Thanks for the responses guys I will try and put a good ground on the HU and take it from there.
Posted: Wed Aug 08, 2018 6:51 am
by amstel18
mellos wrote: ↑Tue Aug 07, 2018 10:55 pm
Crude way I did it was take some flex and strip it and then wrap the copper strands around the outer part of the RCA and then the same on the other end and then take one of the casing screws off at the back of the deck and ground it there.
Sorry if the explanation is a bit unclear.
Posted: Wed Aug 08, 2018 7:39 am
by Unobeat
amstel18 wrote: ↑Wed Aug 08, 2018 6:51 am
I was about to ask about this, thank for a bit of detailed explanation.
Posted: Wed Aug 08, 2018 8:32 am
by DJ7
mellos wrote: ↑Tue Aug 07, 2018 10:50 pm
If connected incorrectly originally, I think an IC or something in the HU blows and then needs the additional grounding to sort out that interference.
Posted: Wed Aug 08, 2018 8:34 am
by DJ7
Wrap the wire around the outer metal part of one of the RCA's and then to the back of the cage of the HU. So not the metal point that goes into the HU, but the outer metal part. If that makes sense.
Posted: Wed Aug 08, 2018 8:47 pm
by mellos
I understand the explanation is fine,thanks a lot.
Posted: Wed Aug 08, 2018 11:30 pm
by Ashveer03
Something called a pico fuse blows, done this "trick" before - it works
Posted: Mon Aug 13, 2018 6:51 am
by mellos
Ashveer03 wrote: ↑Wed Aug 08, 2018 11:30 pm
Where would one find this pico fuse?
Posted: Sun Nov 11, 2018 11:37 am
by mellos
mellos wrote:Ashveer03 wrote: ↑Wed Aug 08, 2018 11:30 pm
Bump
Posted: Mon Nov 12, 2018 6:44 pm
by Ashveer03
Hey bud it's somewhere on the circuit board, I honestly don't know where or what they look like. Some of them look like a diode and others like a tiny wire strand - whenever I had this issue I just grounded out the rcas, didn't try repairing or replacing it..
Google the model number of ur radio, eg "xxxxxx Pico fuse" some1 must have done a repair at some stage
Posted: Wed Nov 14, 2018 7:04 pm
by mellos
Ashveer03 wrote:Hey bud it's somewhere on the circuit board, I honestly don't know where or what they look like. Some of them look like a diode and others like a tiny wire strand - whenever I had this issue I just grounded out the rcas, didn't try repairing or replacing it..
Ok will do thanks....
