Radiator for Crossflow Throttles
Rox_Star
Wheel Whore
Car Make: VW CITI Rox
Car Model: Citi Rox 2l 8v
Membership No: 1992
Post by Rox_Star »
Hi Guys,
My first post and advice seeking mission.
Firstly I drive a Citi Rox, 2l 8v shortblock, stage 3 build by Sarel with single throttle.
Planning on going crossflow Throttles but I’m just having some issues around the radiator. I know cheaper ain’t always better but I just want to find out if any one here has dropped their standard radiator down to allow the trumpets to to get access to fresh air.
I have searched the forum, this topic has been discussed with regards to other radiator options, but I’m just checking if dropping the radiator is a good option. I trust Sarel but personally not sure if I want to cut the car yet.
Much appreciated guy.
__________________________________________
Citi Rox
2.0 8v Shortblock Crossflow Throttles
Built by 8v Performance
298cam, Branch, Exhaust, Diktator Management
110wkw 180nm :twisted:
With some extra Peri Peri
Daily Driven
"Eat sum More"
PapaJo
Car Make: VW's
Re: Radiator for Crossflow Throttles
Post by PapaJo »
Rox_Star wrote: Sun Mar 04, 2018 9:32 pm Hi Guys,
i would like to know the answer too. Heard about this cut and drop too, but also very worried that it will weaken the front valance. It will definitely be weaker with the cut out unless the cut out gets boxed and welded up.
Registered for: 21 years 10 months
We cut a BMW 540 rad in half and mounted the halves behind each other with custom end tanks. Worked a charm.
Rox_Star
Wheel Whore
Membership No: 1992
Post by Rox_Star »
Thanks @Panic. Who did the tanks? Which model of 540 rad did you use? Thing is car is a daily so i sit in a bit of traffic everyday.
Citi Rox
Daily Driven
"Eat sum More"
PapaJo
Car Make: VW's
Post by PapaJo »
panic-mechanic wrote: Thu May 10, 2018 12:14 pm We cut a BMW 540 rad in half and mounted the halves behind each other with custom end tanks. Worked a charm.
Great info, panic
Any chance of having a picture of this to give us an idea?
PapaJo
Car Make: VW's
Post by PapaJo »
Great info, panic
Oh gee no that was around 12 years ago - pics long gone. tanks were built by Aero tig in spartan but I believed he has also passed away since.
Was the first series 540 that came out. so would have been E39 I think?.
I was just the right length to fit snugly in the mk1's nose.
We ran small aftermarket fans and never had heat issues
Rox_Star
Wheel Whore
Membership No: 1992
Post by Rox_Star »
panic-mechanic wrote: Thu May 10, 2018 12:48 pm Oh gee no that was around 12 years ago - pics long gone. tanks were built by Aero tig in spartan but I believed he has also passed away since.
Ok thanks. Google says the E39 tank dimensions are 650mm x 440mm (L x H). This is the correct one right? So we cut it horizontally and get tanks make up for them after they stacked?
Citi Rox
Daily Driven
"Eat sum More"
PapaJo
Car Make: VW's
Post by PapaJo »
Rox_Star wrote: Thu May 10, 2018 12:52 pm
I have searched online and also came to the E39 model and dimensions you got. Looking at radiator flow characteristics then, I think this was made with an entry on the one tank, passing over on the tank on the other end tank to the other core and exiting on the other end tank in front of the tank where it entered. Motor side entered on the core closest to motor and return to head from the front core to prevent the hotter motor water coming out of motor to heat up the second core if second core was sitting at the motor side returning to head. Thermo switch then on bottom corner of end tank passing from one core to the other core.
Correct on the flow. Way too long ago for me to remeber dimensions
PapaJo
Car Make: VW's
Post by PapaJo »
panic-mechanic wrote: Fri May 11, 2018 11:12 am Correct on the flow. Way too long ago for me to remeber dimensions
Thanks for confirming flow, panic.
Rox_Star had nmeasurements higher up in his post 650mm L x 440mm H. Cut in half then relate to 220mm H. Giving plenty free air space as the distance from bottom to top available is 330mm H (110mm open space).
Rox_Star
Wheel Whore
Membership No: 1992
Post by Rox_Star »
PapaJo wrote: Fri May 11, 2018 2:30 pm
Do you know anyone in JHB who is good with custom tanks for Radiators? Still trying to find out who does these aluminum tanks.
Citi Rox
Daily Driven
"Eat sum More"
PapaJo
Car Make: VW's
Post by PapaJo »
Rox_Star wrote: Fri May 11, 2018 3:19 pm
No idea, who in JHB can help you.
Tell us in which area you are and someone can naybe assist in your area or point you to someone close to you.
you can try chris muller at CMS but he will be leaving the country soon.082 807 7209
Rox_Star
Wheel Whore
Membership No: 1992
Post by Rox_Star »
PapaJo wrote: Fri May 11, 2018 4:21 pm
I’m in edenvale area.
Citi Rox
Daily Driven
"Eat sum More"
Armand
Registered for: 16 years
Car Model: Black Magic 6R Polo Gti
Membership No: 1828
Post by Armand »
What type of radiator do they use for side conversion?
2011 Black 6R Polo Gti (Forge intake, Viper dp, Stage 2 DNA sw)
2007 Polo gti (Giac software, 76mm dp, ITG Induction, custom FMIC)
2009 Citi 1.4i sport
1997 Uno turbo ( w/m, Tdo4 turbo, intercooler,76mm exhaust
Bmw 540i e34 (Standard)
Nissan 3.0 v6 (Brospeed branches and exhaust)
2009 Polo gti (Giac software)
Suzuki gsxr1000 k5 (Everything)
Vw caddy club (Mp9 conver, Branches, exhaust, chip)
PapaJo
Car Make: VW's
Post by PapaJo »
Armand wrote: Mon May 14, 2018 7:09 pm What type of radiator do they use for side conversion?
Honda radiator
Ry@n
Registered for: 12 years 8 months
Car Model: VW Caddy 2K 2.0 8v
Post by Ry@n »
My friend also uses a Honda radiator, the one with a dual core I think.
2008 VW caddy panel van 2.0 8v
2012 Nissan Pathfinder 2.5 Dci Le
Rox_Star
Wheel Whore
Membership No: 1992
Post by Rox_Star »
Ry@n wrote: Tue May 15, 2018 3:24 pm My friend also uses a Honda radiator, the one with a dual core I think.
Does it work well in traffic? :crazy:
Citi Rox
Daily Driven
"Eat sum More"
Ry@n
Post by Ry@n »
No overheating at all!
MarshallGTi
Registered for: 13 years 2 months
Car Model: Ibiza 1.9TDi FR
Membership No: 1665
Post by MarshallGTi »
Hetdre radiators in Meyerton does great tank fabrication
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
PapaJo
Car Make: VW's
Post by PapaJo »
MarshallGTi wrote: Tue May 15, 2018 4:50 pm Hetdre radiators in Meyerton does great tank fabrication
Ok, thats in my town. Will find them.
Rox_Star
Wheel Whore
Membership No: 1992
Post by Rox_Star »
PapaJo wrote: Tue May 15, 2018 8:11 pm
Please keep us informed on how it goes and if u win withthe design and fit :hurray:
Citi Rox
Daily Driven
"Eat sum More"
PapaJo
Car Make: VW's
Post by PapaJo »
Rox_Star wrote: Thu May 17, 2018 2:42 pm
Ok, will do.
Old School Quintin
Registered for: 10 years 10 months
Car Model: MK1 16v
Post by Old School Quintin »
Any news on the build and what radiator was used
2008 VW CitiRox
Abf 45mm ITB
Under construction
Seeking ponies
