Polar White Mercedes C63 - Detailed by Lawrence
A good client of mine recently purchased this vehicle and knew that despite it being new, there would already be contamination on exterior surfaces and some below-surface defects like swirls and scratches. By removing these and then 'sealing it in' with hydrophobic 'wax'/'sealant'/'coating' [which will depend on your specific situation] you make the car easier to keep clean in a way that reduces swirls (fine 'spider web' like scratches reduce the optical clarity / shine of the paint).
The vehicle was detailed near the beginning of March.
The engine bay had a lot of 'dusty' type dirt (as opposed to say an old oil leaking engine that was greasy/grimy). The carpeted section on the underside of the bonnet was brushed out then the engine bay blown out using an electric blower and then gently wiped cleaned using Mothers Carpet and Upholstery cleaner. The engine bay was cleaned using Carchem APC @ 1:5, various brushes, q-tips, microfibre towels and a dedicated (to the engine bay) lambswool wash mitt. The plastics were dressed using Carchem Vinyl and Rubber dressing, and the painted surfaces protected using Gyeon Cure.
Before
After
Arches: Rinsed with a pressure washer, sprayed with Carchem APC via a foaming trigger head and allowed to dwell and then agitated with a large Wheel Woolie. This was followed with another pressure rinse.
Tires: Cleaned with Carchem APC and a Mothers Tire Brush and later dressed with Carchem Trim and Tyre Dressing
Wheels and brake calipers: Rinsed with a pressure washer then cleaned using Carchem APC and a Wheel Woolies and a Autofinesse Boar Hairs brush and dried. The wheels were then thoroughly sprayed with Carchem Revolt which was agitated after being allowed to dwell for a few minutes, using the same brushes, and then thoroughly rinsed and dried them.
Carpro TarX was used to remove any tar spots. The wheels were then foamed using Turtle Wax Hyperfoam when the rest of the car was being washed - this would ensure there were no remaining residue on the surface. They were then sealed using Carpro Hydro.
Door shuts, boot shut, window rubbers, fuel flap, badges etc: Cleaned using Carchem APC with Autofinesse brushes and then pressure rinsed. Autofinesse Tripple was then used to further clean these areas and leave behind some protection.
Wash: Pre-foamed using Turtle Wax Hyperfoam via a foam cannon
Followed by a 2BM wash with Lambswool wash mitts and Carchem Luxury Shampoo.
Dry: ONR at QD strength with WW Drying towels and an electric blower
Decontamination: Carchem Revolt, Carpro TarX and Shield Heavy Duty Grade Clay with ONR as lube.
Correction: Carpro Essence / Lake Country Orange Hybrid / Flex 3401
Before
After (excuse the lint from the mf towel - this was cleaned up using Gyeon Prep prior to applying Gyeon Cure)
Before
After
Protection: Gyeon Cure
Glass : Autoglym Fast Glass Cleaner / Wynns C-Thru
Door rubbers, plastic trim : Shield Heavy Duty Vinyl and Rubber Cleaner / Carchem Trim and Tyre Gel
Interior plastics : Shield Heavy Duty Vinyl and Rubber Cleaner / Optimum Optiseal
Interior carpet : Vacuum / Brush / Vacuum
Interior leather : Collinite 855
Exhaust tips: Carchem APC / Mothers Mag and Aluminium Polish / Mothers Powerball
The number plate holders were removed and the old glue residue cleaned off
a
Some pictures of the completed car
And lastly my favorite shot.
Total time spent = 22 hours
As always thanks for looking and any questions or comments are welcome.
:hi:
stig
Car Model: Polo 1.9 TDi Highline 96KW
Membership No: 2083
Re: Polar White Mercedes C63 - Detailed by Lawrence
Post by stig »
Very very nice lawrence. Could you please explain the Drying p4ocedure using the ONR AND BLOWER
The Ride:
H&M Dyno Night: 114KW 429NM
Rsi huntered
Registered for: 16 years 9 months
Post by Rsi huntered »
:drool: :drool: :drool:
Came out :drool:
Tiguan 2018 R-Line :evil:
Polo 6C Ex
2004 Golf 1 Baby 1.4i +VAT :evil: 76.3 WHP@K.A.R
Polo 2008(9n3)Ex:-(
Golf 1(2 door)branch,exhaust,domingo's,leather seats,electric windows, 2.0L 16v ( sold ) :cry: Ex.
Golf 2 2L 16v full house(RIP) :bang: Ex
Kuvi
Membership No: 2101
Post by Kuvi »
Looks stunning. Nicely done bud
stig wrote:Very very nice lawrence. Could you please explain the Drying p4ocedure using the ONR AND BLOWER
When I am finished rinsing the car I will use an open ended hose to sheet water off the car (you should be able to find a YoutTube vid for the technique)
This reduces the pools of standing water typically left over when rinsing by spraying water from a hosepipe or pressure washer.
Then BEFORE I start actually drying, I will spray the car down with ONR ar Quick Detailer Strength (you can you any quick detailer or spray wax/sealant). This will provide some lubrication between the drying towel and the paint, helping to reduce swirls.
The blower is used to help force water out from places like mirror housings, door handles, badges/emblems, honeycomb areas, lug nuts, door jambs etc etc. in order to stop those annoying runs down the side of the car that inevitably happen without it.
Rsi huntered wrote::drool: :drool: :drool:
Came out :drool:
:hug:
Kuvi-VPS wrote:Looks stunning. Nicely done bud
Thanks very much!
Mbuzi
Car Model: Q5
Membership No: 1964
Post by Mbuzi »
Nicely done L :hug:
8VALVE-zn
Registered for: 12 years 8 months
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Post by 8VALVE-zn »
Top stuff boss man!!
The Shaikh
Registered for: 10 years 2 months
Membership No: 3010
Post by The Shaikh »
This is just too nice, so clean, so reflective.... :drool:
This is the money shot
If you are interested in something, No matter what it is
Go at it full speed
Embrace it with both arms
Hug it
Love it
Above all become passionate about it
Lukewarm is not good enough
Mbuzi wrote:Nicely done L :hug:
Thanks Themba
8VALVE-zn wrote:Top stuff boss man!!
Shot bud :hug:
The Shaikh wrote:This is just too nice, so clean, so reflective.... :drool:
Glad you like it :thumbup:
Wideopn-ZN
Post by Wideopn-ZN »
Beautiful car....beautiful outcome. I love that we sound surprised that at the outcome of a car after a weekend in the care of The Lord of The Sponge.....
Awesome as always Lawrence.
DINODENASH
Registered for: 17 years 2 months
Car Model: BMW e46 Individual
Post by DINODENASH »
What a car !
What a detailer !
Came out tops bru !!!
wowy ....those pics ....dammm
Wideopn-ZN wrote:Beautiful car....beautiful outcome. I love that we sound surprised that at the outcome of a car after a weekend in the care of The Lord of The Sponge.....
:hug: Thanks so much Dave!!!!
DINODENASH wrote:What a car !
What a detailer !
Thank you Dino :hi:
Polo Playa 1.8
Post by Polo Playa 1.8 »
Awesome Lawrence
VW POLO PLAYA 1.8
Polo Playa 1.8 wrote:Awesome Lawrence
Thank you :hug:
ibaa
Post by ibaa »
Hi thanx for the topic! May i ask plz.. what foam shampoo and foam canon do you use?
ibaa wrote:Hi thanx for the topic! May i ask plz.. what foam shampoo and foam canon do you use?
I use the foam canon sold by Crazy Detailer here
In terms of foam, on this specific detail it was Turtlewax Hyperfoam but others I regularly use are:
Valet Pro Advanced Neutral Snowfoam
Carchem Luxury Snowfoam
Gyeon Foam
Angelwax Fast Foam
You also have options like Carpro Ironx snowfoam (which has some iron x for decon built in) or their Hydrofoam which has Carpro Hydro built in (for protection)
I use the foam canon sold by Crazy Detailer here http://www.crazydetailer.co.za/index.ph ... ts_id=1337 connected to a Karcher K7 pressure washer
Gyeon Foam
Angelwax Fast Foam
Edited to add in the link to the canon
Reegz
Registered for: 19 years 8 months
Membership No: 1400
Post by Reegz »
Damn! That's some great work bud!
2016 Golf 7 Tyre Devourer
---- Ex ----
2012 Golf 6 GTi Edition 35 - RIP :-(
2008 Honda CBR 600RR - SOLD
1996 Citi Golf CTi - SOLD
Reegz wrote:Damn! That's some great work bud!
Thank you!!!!
mahadeo.akshar
Post by mahadeo.akshar »
Hi i would like to contact you for a detail.
you did a great job
I have a 2005 golf 1
Uvy
Registered for: 21 years 3 months
Car Make: VW and Seat
Car Model: MK2 GTi 16V Golf
Membership No: 1740
Post by Uvy »
Awesome stuff LA. You added like 100k to the price of that car.
Heaven on Earth - VAG for life
