mr turbo help
ob wan
Car Model: MK1 2.0 16vT
mr turbo help
Post by ob wan »
morning
need the help of the guru's here please
installed a mr turbo ecu on a mk2 abf, got a 9a dizzy, car started and ran fine, it's a single coil&dizzy ecu
now i can't get a signal to the ecu, when i remove the dizzy and turn it by hand, i can hear the injectors pulsing and the fuel pump pumping
when i put the dizzy back in the car, nothing, earths are fine and terminals are tight
help please
05 G5 Gti (ex)
97 LSvtec (ex)
05 Ford Ranger 4.0 V6
Mk1 velo 2.0 16v...Turbo
ob wan
Re: mr turbo help
Post by ob wan »
problem found, power drop when starter engages... :bang:
05 G5 Gti (ex)
97 LSvtec (ex)
Viper
Goldwagen Delarey
Registered for: 14 years 4 months
Car Model: GOLF 1 1870cc 8v ethanol
Membership No: 1800
Re: mr turbo help
Post by Viper »
Eish that's a tuff one. Maybe something earth related. I never had that problem before. I always go for 60-2 setups
ob wan
Re: mr turbo help
Post by ob wan »
turned out to be the relay in the mr turbo wiring harness,
now i don't have spark....
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Re: mr turbo help
Post by ob wan »
replaced tp100 and all is well now
05 G5 Gti (ex)
97 LSvtec (ex)
Timjive-o
Re: mr turbo help
Post by Timjive-o »
ob wan wrote: Wed Aug 17, 2016 2:30 pm turned out to be the relay in the mr turbo wiring harness,
Howzit man just need to know which wires go to the relay on the Mr turbo efi box loom from the connector. Like terminal 30,85,86,87 which wires goes to each terminal from the efi box loom connector to the relay
