Citi Golf - C-Notch
Wheelwore
Car Model: MK1 Velociti 1.6i
Citi Golf - C-Notch
Post by Wheelwore »
Im trying to find the link of a DIY C-notch on the Citi Golf...
Is there any cables running through that might get cut?
2007 - Velociti 2.0 ABF Black Magic
2008 - Velociti 1.4i Midnight Blue
2002 - Chico 1.4i White - Chicolux
1996 - VR6 2.8 Golf
Torker
Registered for: 18 years 10 months
Car Model: Golf GT
Membership No: 1464
Re: Citi Golf - C-Notch
Post by Torker »
Wheelwore wrote:Im trying to find the link of a DIY C-notch on the Citi Golf...
On the front chassis horns? There are no cables running through there...
Current rides:
Hyundai - 1.4 Getz (daily)
Naku786
Cake Laaitie Killer
Car Model: Citi 1.9i 8v
Post by Naku786 »
No...
A pic
THere a is a lot of debate around notching... some say its bad an alters the strutural integrity of the cars chassis and could lead to all sorts of issues in a accident... other say you live once so **** that I wanna go low dammit :lol:
Some reading
http://forums.vwvortex.com/showthread.php?4281067
http://forums.thecarlounge.com/showthre ... e-notching
THANAS
Car Model: AW Polo GTi
Membership No: 2035
Post by THANAS »
Wow that's an extreme notch. I took about 15mm off with a dremel and a grinding bit and that gives me enough clearance to be low enough to rub my tyre against the arches before the drive shaft grinds against the chassis even over bumps. I can guarantee that the amount I took off is insignificant in terms of effect to the structure. Unless you're on air you don't need such a hectic notch.
Sent via Hedwig
PoLonY
Registered for: 15 years 6 months
Car Model: A8
Membership No: 1997
Post by PoLonY »
CitiCitiBangBang wrote:Wow that's an extreme notch. I took about 15mm off with a dremel and a grinding bit and that gives me enough clearance to be low enough to rub my tyre against the arches before the drive shaft grinds against the chassis even over bumps. I can guarantee that the amount I took off is insignificant in terms of effect to the structure. Unless you're on air you don't need such a hectic notch.
Sent via Hedwig
no static can easily go low enough to need a notch...
Wheelwore
Post by Wheelwore »
Sent via Hedwig
so you didnt strenghthen afterwards...you just removed
1996 - VR6 2.8 Golf
THANAS
Membership No: 2035
Post by THANAS »
There's nothing to strengthen I just ground a bit off of the lip. Doesn't look anything like the image above.
Sent via Hedwig
Justin_B
Car Model: Up!
Membership No: 2024
Post by Justin_B »
Check the story of my life thread, he did a notch himself.
