Electrical, mk1: lights and accessories cut out briefly
Re: Electrical, mk1: lights and accessories cut out briefly
Are those keys not coded? Do you have a spare key to try?
- Registered for: 21 years 3 months
- Car Model: 2017 Cross Polo 1.2 TSI
There's a transponder there on the switch, but I think that's on a different bit of loom so this could work.
You know, of course, that this problem will now suddenly stop happening ...
2017 VW Cross Polo 1.2TSI
2006 VW Citi 1.4 carb
1995 VW Chico 1.3 4-speed
1989 Audi 500 turbo (the end. finally.)
So I unplugged the ignition switch, hooked up the new one, left key in old barrel for transponder, turned the new switch and all electrics go off.
I reckon that should indicate it isn't the ignition switch itself.
Replaced the starter today. Got stuck at the mall on Christmas Day trying to get the damn thing to start. Only got it going by hand-shorting the solenoid and it would keep disengaging. The electrics didn't cut out, but the starter just wouldn't engage long enough.
Removed all connections, cleaned them all, used Electro Kleen on every connection.
I need to figure out how to fit these fuse holders I bought:
To replace those stupid BMW blade fuse holders.
Do you have a spare key?
Yes. Why?
I used that to turn the new switch.
Both work fine. No weirdness with either key.
- Medres
Have you checked the relays that are in the dash behind the head light switch?
- Registered for: 21 years 9 months
Yup that negates the ignition switch theory.
A week with no issues since cleaning all contacts around battery and earth points in engine bay.
Running around this week before work and school starts on Monday. Going to get under dash on Saturday if time permits. I'll clean an tighten contacts where I can. Then I just want to make a bracket to mount new fuse holders.
Might be working now, but I don't trust those blade fuse holders.
Hi guys been having almost same problem mk1 1.4i when using indicators dash lights would flicker with indicators and started now when driving at night lights on when using brights car would cut briefly and come back on resetting watch and trip meter. Did replace fuses next to battery gave and gave fuse holder a good spray with electro cleen same with earth cable? Anything else i can do? Maybe buy a new earth cable
i still used to have that issue. Unfortunately car is parked up at the moment, haven't got round to taking it further.
I bought a pair of maxi fuse holders from 4x4 Direct to replace those blade fuse holder blocks and give some protection from the elements.
I just think the fuse holder is rubbish. Damn thing has a BMW emblem on it.
- Car Make: VW Golf
- Car Model: Last MK1
I'm searching old threads. My 2009 1.6i is doing exactly the same.
Indicators on (left) - car dies. Looks like the rev counter stutters until it gets power, radio in safe mode, time and trip resets to zero.
Brights on - car dies and recovers. Then after this event, applying brakes and indicating also dims the dash.
When I pull the main fuses and push them back, no issues.
Will start my cleaning and stripping if I don't find answers to the issue.
Rides:
1992 Ford Sapphire 2.0i (Sold)
1998 Opel Corsa 1.3i (Smashed)
2000 VW Polo Playa 1.6i (Rolled)
2005 Honda CBR 600RR (Sold)
2005 Honda Shadow VT750 Cruiser (Sold)
2007 Suzuki GSXR 600 (Stolen)
2006 Yamaha R6 (Sold)
2004 Opel Corsa Lite + (Current)
2009 VW Citi MK1 Ltd (Current)
2012 KIA K2700 Bakkie (Current)
2014 VW Polo Vivo 1.6 Trend (Current)
2014 Honda CBR1000RR SP (Current)
1985 Mercedes W123 230e (Project)
2020 VW T-Cross (Current)
Cut out that whole fuse holder set up and replace with something else.
https://4x4direct.co.za/fuse-holders/85 ... -fuse.html
Seems like a better option than that fuse holder in the citi which seems to have come from some old stock BMW parts bin.
Ignition switch is the culprit every time.
No need to modify the wiring or replace the fuse box.
That little R50 switch is a bastard and will not hesitate to make you crazy while it takes your virginity. When it wears out the sheer number of gremlins and random crap that happens is insane.
Hi guys, my 2008, 1.4i is doing the exact same. Been to a few auto electricians but none can seem to find the fault. Please advise if replacing the ignition switch rectified the pro lem
sramnarain wrote: ↑Thu Jul 20, 2023 2:15 pm Hi guys, my 2008, 1.4i is doing the exact same. Been to a few auto electricians but none can seem to find the fault. Please advise if replacing the ignition switch rectified the problem
