Howzit guys. The battery on my golf 5 2.0 is always going down. The battery can't be at fault cause I changed it about a year back. The only thing I did recently was put a golf 6 gti MP3 player on the car but I'm not sure whether after that then the battery started going down. Any clue what's wrong guys?
TIA
Golf 6 RNS510 unit battery drain issue fix
- Registered for: 18 years 11 months
- Membership No: 388
Re: battery draining
The golf 6 radios will draw the battery if you dont code the car for it or have the correct gate way installed.Remove the radio and check it again.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
- Post Whore
- Membership No: 1343
You need to do the following.... I did this fix on my car and the battery is 100% fine. I also have a rcd310 the newer spec mp3 vw radio.
Used this technique to have a small harness made up to cope with the issue explained below...
"I have an easy not techinical solution for those of you that has a RNS510 unit and have the battery drain issue. So if you do not want to go through the hassle of finding a new canbus and recoding your canbus for your car try the method below. I have been using this method for over a year now with not problems at all."
Step 1:
Step 2:
Step 3:
Step 4:
Step 1:
Step 2:
Step 3:
Step 4:
- MarshallGTi
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
does ur car having a tracking device?
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
EX-DOHCTOR wrote: I'd make sure I understand the differences between fish and engine components before attempting any modifications on my motor vehicle as a start.![]()
- Post Whore
Wouldn't be the tracking device. The golf 6 radios draw more power from the battery than mk5 ones would, even with the car switched off it draws power. You can either do this fix or buy a new CANbus unit from vw or a scrapyard and have it coded via vcds.
Thanks for the help guys. Will try that fix tonight
- MeanTdi
- The Imposer Mod-whore-rator
- Car Make: Subaru
- Car Model: WRX
- Membership No: 1153
Re: Golf 6 RNS510 unit battery drain issue fix
Golf 6 RNS510 unit battery drain issue fix & DIY fix.
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Current: Subaru WRX
Ex: VW Golf VR6
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
There's an even neater way IMHO.
It would be neater to open the fuse box and move the radio fuse terminal to a switched slot.
Just move the radio fuse - open the box, remove the wire/plug from where it is, to the switched area. Then plug the fuse in normally.
