Turbo Care *Recommendations for Servicing and Care*
MeanTdi
The Imposer Mod-whore-rator
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Post by MeanTdi »
Turbo Care - Recommendations for Servicing and Care
The following recommendations come from years of experience as well as guidelines from the world's leading turbocharger manufacturers.
How to care for your turbo
In theory, a turbo is designed such that it will usually last as long as the engine. It does not require any special maintenance; and inspection is limited to a few periodic checks. However, to ensure that the turbo's lifetime is prolonged, the following engine manufacturer's service instructions must be strictly observed:
- Oil change intervals
- Correct oil as specified by engine manufacturer
- Oil filter system maintenance
- Always ensure correct oil-pressure is maintained
- Air filter system maintenance
- On diesel engines, use the best quality diesel available
- Poor quality diesel will block the catalytic converter, which will lead to turbo failure
- It is not uncommon to remove/replace blocked catalytic converters in order to prolong the life of the turbo
- Never tamper with the vehicle’s Engine Control Unit (ECU) by “chipping” or “mapping” - your turbo is not designed for this
- Always ensure services are performed by a reputable mechanical workshop
Turbo failure - causes
90 % of all turbo failures are due to the following causes:
- Penetration of foreign bodies into the turbine or the compressor
- Dirt in the oil
- Inadequate oil supply (oil pressure/filter system/carbon-build-up in oil-supply pipe )
- High exhaust gas temperatures (ignition system/injection system)
- Faulty electronic actuator on turbocharger
- Many of these failures can be avoided by regular maintenance. When maintaining the air filter system, for example, care should be taken that no foreign material gets into the turbo.
Effect of rebuilding an engine
Rebuilding an engine could have an effect on the turbo as follows:
- Loose carbon, if not flushed out before fitting the turbo, will lead to turbo failure
- Grinding-paste, if not flushed out properly before fitting the turbo, will lead to turbo failure
- Always ensure your engine is rebuilt by professionals!
Turbo installation
When fitting a turbo, the following should be checked carefully:
- Air Intake
- Oil Supply
- Exhaust Manifold
- Oil-supply and drain pipe for leaks, foreign bodies & restrictions and replace or clean as necessary.
- You ensure that the oil is that recommended by the engine manufacturer.
- You ensure lock-plates to be fastened after realignment.
- Remember that the unit contains little or no oil and must be pre-oiled by pouring clean oil into the turbo centre housing oil inlet for initial lubrication.
- Install turbo on engine replacing all gaskets. Ensure no gaskets sealants or compound are used - a small amount of silicon inside a bearing-housing will lead to turbo seizure.
- Leave oil pipes disconnected and crank engine until oil flows from feed pipe with the fuel shut-off in die “off” position and the solenoid disconnected (on engines equipped with electric shut-off.)
- Connect oil feed pipe.
- Crank engine until oil flows from oil outlet.
- Connect drain pipe and crank engine for 5 seconds.
- Start engine and idle for 3 to 5 minutes before accelerating.
- Before engine is switched off it is important that it is allowed to idle for 3 to 5 minutes.
Failure diagnosis
If the engine does not operate properly, one should not assume that the turbo is the cause of failure. In many cases a turbo is replaced, although the fault is engine-related and not caused by a faulty turbo. It might be that the problem shows up at the turbo, although the turbo is in perfect condition (for example engine blow-by/sump-compression, pushing oil through the oil-return back and forcing oil past the oil-rings of the turbo). In other cases, an engine-fault could damage the turbo, and after replacing the turbo, the engine still needs to be attended to.
In general, the following could also play a role in proper functioning of the turbo although it's not part of the turbo:
- Air-mass meter
- Boost-control sensors
- Pressure-regulators
- Engine Gas Recirculation (EGR) valve
- Engine Control Unit (ECU)
- Boost-pipes
- Intercooler
http://www.turboworks.co.za/gpage3.html
Last bumped by MeanTdi on Wed Jan 22, 2014 9:25 am.
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
