fault codes Vr6
Registered for: 19 years
Car Model: Mk2 Gti 8v
fault codes Vr6
Post by 38 »
01251 - Fuel Injector for Cylinder 3 (N32)
31-10 - Open or Short to Ground - Intermittent
01252 - Shareware Version. To Decode all DTCs
31-10 - Please Register/Activate - Intermittent
01247 - Shareware Version. To Decode all DTCs
01253 - Fuel Injector for Cylinder 5 (N83)
01254 - Shareware Version. To Decode all DTCs
Readiness: N/A
What could this possibly be?
BMW E30 325i
Jetta 6 1.4 TSI
Ex-MK2 Gti 1988 1800, 8v OEM
Ex-MK1 Gti 1985 , CTI injection.
Ex-MK3 Vr6 97exec(standard).
Ex-VFR 400(NC30) 1992, aftermarket Can.
Ex-MK1 2door- 1800 8v, 4-1 branch,powerflow 50mm(RIP)
Ex-1990 Mk2 CSL Jetta aka VR1(Sold)
Ex-1987 Toyota Corolla 1.6GL slantfront(stolen)
Rides thread : http://www.vwclub.co.za/forum/viewtopic ... 4#p2505684
MK2 G60
Membership No: 388
Re: fault codes Vr6
Post by MK2 G60 »
Check the injectors and there wires between the injector and ecu as well as the 12v supply for the injectors.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
38
Re: fault codes Vr6
Post by 38 »
I will check the connectors and all of the above. I bought this engine recently so its possible that there could be some old muck inside the connectors.This motor probably stood for 10 years or so.
I cant seem to find my old motors wiring harness. I want to swop the injectort rails harness and see if that makes a difference.
BMW E30 325i
Jetta 6 1.4 TSI
vr6zn
Car Model: 1998 MK3 VR6 Golf
Re: fault codes Vr6
Post by vr6zn »
you did check that the engine you bought is obd2?
Six is always better then four!
1998 Golf VR6 (Durban Stock)
2001 Polo Playa 1.4i
1994 Jetta VR6
1992 1.3 Citi Golf
Yakuza Racer
Voora Molester
Re: fault codes Vr6
Post by Yakuza Racer »
vr6zn wrote:you did check that the engine you bought is obd2?
yes is an OBD2 motor
Thupercharged S4
