Jetta Mk2 1.8 Carb Vacuum Hose connections
Hwzt Guys
I have been struggling to get a correct diagram to help me connect up the vacuum hoses for this carb,
I have come across this diagram, but i tried working with it and it seems its for the wrong carb.
does anyone have a diagram of how these hoses are connected? When I do connect stuff up, even to the idle speed control valve, the idle picks up to 1100rpm, and in traffic it went up to 2000rpm!!
I came across this diagram from the haynes manual:
Kinetic Garage
0849991860
0849991860
- Colonel
- Membership No: 1041
Re: Jetta Mk2 1.8 Carb Vacuum Hose connections
ok that diag is for the Solex carb, you would need the diag for the Keihn carb.
What pipes are not connected or are you not sure about?
Ah, i didnt know what carb it had.
The pipes from the airbox is not connected at all. There is one vacuum hose connection at the back of the carb that is not connected, it is blanked off with a piece of pipe and a screw, and most importantly the idle control valve: this has 3 connections, 2 at the top and one at the bottom, the 2 at the top is connected but the bottom one is left empty i.e sucking the air from the atmosphere. My idle is really jerky at low revs and I am sure that this vacuum pipes are the answer to that problem.
Kinetic Garage
0849991860
0849991860
- vr6zn
- Car Model: 1998 MK3 VR6 Golf
Connect the one from the back of the carb straight to the distributor, disconnect the idle control valve by blocking the vaccum pipe coming from the non return valve to it. check the vacum pipe from the front of the carb goes to the choke vacum.
this is what i did to my dads jetta and it runs fine now.
Also check your baseplate, this causes the idle to increase.
Six is always better then four!
1998 Golf VR6 (Durban Stock)
2001 Polo Playa 1.4i
1994 Jetta VR6
1992 1.3 Citi Golf
1994 Jetta VR6
1992 1.3 Citi Golf
Hwzt, il check that. The base plate is brand new, my mechanic just replaced it for me. I dont understand why mechanics don't do a job 100%
Kinetic Garage
0849991860
0849991860
- Car Make: Jaguar
- Car Model: X-Type 2.2D
Return business. Only a know a handful of honest mechanics.Twisted wrote:I dont understand why mechanics don't do a job 100%
Current: Jaguar X-type 2.2D
Ex: 2000 Citi 1.3
Ex: 2000 Citi 1.3
true? my mechanic is my dad's friend, someone whom we trust.tamper_man wrote:Return business. Only a know a handful of honest mechanics.Twisted wrote:I dont understand why mechanics don't do a job 100%
I just noticed that my car, when I start her up in the mornings or if i start her up after a few days, is very rowdy and jerky at low revs.
So i am guessing its the vacuum pipes, because when i connected a pipe from the non return valve to the idle speed control valve, the revs pick up and idles smoothly at 1100rpm
Kinetic Garage
0849991860
0849991860
- Membership No: 388
The one behind carb gos to dist and the one from the perminanat vacume gos to the air filter [in pick it runs to dist]
The front one gos to the diaphram on the side for the choke section.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
hwzt guys
I still haven't found the right way around to connect this pipes. I did exactly as I was told by the members above ^^ but still havin a hassle.
When i press the accelerator on idle, the car revs dip down, and then pick up again, takes about a second, its a rough dip, and if you really press the accelerator in hard, the car can switch off, it looks like its getting too much of air.
Can anyone recommend a person in Durban i can go and get this connected properly? I am thinking of taking it to VW themselves.
I am sure all these vacuum pipes affect fuel consumption, and previously when you put the aircon on, the car raises the idle, but now with the configuration above ^^ the idle dips alot!!
Remember I apparently have the keihn carb, and there is hardly any info out on the net with regard to this carb.
Twisted
Twisted
Kinetic Garage
0849991860
0849991860
- Colonel
stop wasting time and go to Carburettor Ace in Stamford Hill - 031 3031966
- aarchaic
- Car Model: 1991 Jetta Clx Mk2
- Membership No: 1628
sometime the pipes cracks and sucks air... also the diaphragms starts cracking after all the years. but best is let someone check the carb. 1100rpm is a bit high for idling also it needs to be in the area of 950
Membership Number: 1628
1991 Vw Jetta MK2 CLX ( ADY 2.0, 8v 282 cam , 96.7hp atw 144 Nm )
91 Vw Jetta Mk2 Build - ADY - Dyno Graph Pg 16
In Car Entertainment Build & Install Completed - Thread
Jeremy Clarkson : “I'll tell you what. We'll try it my way first... and then we'll finish!”
Hwzt
I have all new vacuum pipes and I have a new carb base plate, i am really positive that its just the way its all connected up hey...
Kinetic Garage
0849991860
0849991860
- Tdi jetta 4 ever
Sounds more like a carb problem. Maybe float level or the jetting is dirty or wrong.
Robin
robinwisse@gmail.com
Hi, could this cause my 1989 mk 2 golf csl 1.6 not to idle. I must keep on revving it, otherwise the car switches off. It feels as if it is not getting petrol.
