9a and pl mk1 conversion possible
162life-WP
Registered for: 7 years 1 month
Car Model: Mk1 Life
Re: 9a and pl mk1 conversion possible
Post by 162life-WP »
blou_poot wrote:Fitted the switch today.
Cant believe this had me struggling fidling with other stuff.
https://youtu.be/lUNYdioJpho
Thanks for all the help. Next steps:
-timing
-exhaust
-fitting mp9 throttle body
-dyno
-change some water pipes
- fasten inner cvs
- new shock mounts
- alignment
- solder and cover wires including mounting point for the start button.
-enjoy enjoy enjoy...
No specific order except for the last part
Sent from my RNE-L21 using Tapatalk
Mooi gewerk man pal. I can see ur smile through my fone lol
Glad u came right. Hoping to see dyno numbers soon!
Sent from my FIG-LX1 using Tapatalk
blou_poot
Car Model: Chico golf 1.3+Vat
Post by blou_poot »
Will share as soon as i have dynoed the car.
96' Chico 2.0 Carb
PapaJo
Car Make: VW's
Post by PapaJo »
Well done!!!!
I’m sure you are over the moon happy to hear that motor idle.
blou_poot
Post by blou_poot »
Very... Got so frustrated and demotivated.
Motor sounds very healthy... but will check tomorrow once i have time again to work on the car.
96' Chico 2.0 Carb
PapaJo
Car Make: VW's
Post by PapaJo »
blou_poot wrote: Mon Jun 25, 2018 8:31 pm Very... Got so frustrated and demotivated.
Glad you kept pushing on.
blou_poot
Post by blou_poot »
End is near...
Almost sold the car over the weekend... Wouldve been sad today... If it was gone.
96' Chico 2.0 Carb
PapaJo
Car Make: VW's
Post by PapaJo »
blou_poot wrote: Mon Jun 25, 2018 8:53 pm End is near...
Don’t ever give up!!
blou_poot
Post by blou_poot »
I shall not...
Thanks for all the help from this forum...
From clueless to little less clueless over the years..
Helped a couple of people over the years... Even some strong 8vs running round here with my help and knowledge i built up on this forum as well as trial and error.
96' Chico 2.0 Carb
PapaJo
Car Make: VW's
Post by PapaJo »
blou_poot wrote: Mon Jun 25, 2018 11:15 pm I shall not...
That’s the spirit.
PapaJo
Car Make: VW's
Post by PapaJo »
Where is the updates??
blou_poot
Post by blou_poot »
None so far... Got a dizzy cap from rowland last week.
Got the flange back but not happy with the result. Was even trolling the web for throttles or abf intake with throtlle body.
However i will be steeling with pride to get flange made up as per images or similar. Will get the flange back on thursday or friday. Made a dummy flange out of steel now they will make it out of aluminium again.ImageImageImageImageImage
96' Chico 2.0 Carb
162life-WP
Car Model: Mk1 Life
Can I just what made u decide to change the throttle body?? Are there benefits in changing? Mine as is, is still working perfectly
blou_poot
Post by blou_poot »
The plastic parts are brittle that hold the cable... Also thought it easier to use the single throttle rather than the dual butterfly... nd its oval... So getting the right size fitting js an issue as mikes did not send the air fitting along.
Hopefully this will not cost me too much kw...
96' Chico 2.0 Carb
PapaJo
Car Make: VW's
Post by PapaJo »
Cool, a flange like that will work 100%.
blou_poot
Post by blou_poot »
Great news.... Small things left to do...
Another question. One the 16v dizzy why does it turn so difficult vs the 8v in terms of adjusting the ignition timing?
Should i elbow grease the rubber seal? Or would that not help at all?
96' Chico 2.0 Carb
PapaJo
Car Make: VW's
Post by PapaJo »
blou_poot wrote: Tue Jul 17, 2018 7:25 pm Great news.... Small things left to do...
The o-ring is forming a tight seal and makes it harder to turn. You can smear a thin layer of vaseline on to help a bit. I would not worry too much about it being tight to turn the casing.
162life-WP
Car Model: Mk1 Life
+1
blou_poot
Post by blou_poot »
Great thanks... Will give updates as soon as available.
96' Chico 2.0 Carb
for future reference - Viper - goldwagen delarey has the drawing and can cnc such a flange for you.
blou_poot
Post by blou_poot »
Noted. Being in Namibia comes with its own hassles
96' Chico 2.0 Carb
Courier don't exist there?
blou_poot
Post by blou_poot »
Lol Panic, they do.
Just did not know about GW.
Next time i will ask.
96' Chico 2.0 Carb
blou_poot
Post by blou_poot »
This is what i went with.
Tapered to fit the manifold from the mp9 throttle body.
Will let you know once installed.
96' Chico 2.0 Carb
PapaJo
Car Make: VW's
Post by PapaJo »
Are you going to leave it with a sharp edge? Any particular reason for that?
blou_poot
Post by blou_poot »
No reason... Should it be more rounded in the smaller part of the tapper?
Would this negatively affect airflow?
96' Chico 2.0 Carb
