280mm bolt on Brake upgrade kits for MK1 is here!!!
Delarey Racing Developments specializes in standard automotive and custom performance automotive parts
Kyli3boi
Registered for: 10 years 10 months
Re: 280mm bolt on Brake upgrade kits for MK1 is here!!!
Post by Kyli3boi »
I didn't buy the calipers from them just the disks and spacers, I don't mind if I have to buy new calipers it's just I need to get this sorted ASAP
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
The kit is designed for a citi and to work with stock calipers.
Go see them on Tuesday and I am sure they can get you sorted out.
Viper
Goldwagen Delarey
Registered for: 14 years 4 months
Car Model: GOLF 1 1870cc 8v ethanol
Membership No: 1800
Post by Viper »
Hi mr. I will message you now
AlexTDi
Registered for: 13 years 10 months
Car Model: '15 Polo GTI
Membership No: 1724
Post by AlexTDi »
Check that the mounting points on the hub carriers are straight and not bent in or out.
These things:
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Kyli3boi wrote:Hi,
I bought this kit from you guys and I have a big problem with both carriers hitting into the disk, the left side I have grinded more than half the thickness of the carrier away and it still hits into the disk, the right side also hits into the carrier but not as bad. Have you had any other complaints about this with your most recent spacer brackets? I'm just wondering if maybe the brackets were not machined correctly? Please let me know how I can solve this issue as I'm not comfortable with grinding more away on the carrier, this is on a golf mk1 with the standard calipers, your 280mm disks and your spacer brackets
All sorted out. He was here this morning with everything . His calipers are aftermarket pirate once and the brackets crossing the discs is thicker . So with the std 237mm it doesn't matter but with the 280mm discs the larger diameter is just to much. We took the pencil grinder to it and cleared just enough the give the discs some space. So now we know that there are some clearance issues with the aftermarket calipers .
Vernon
Registered for: 12 years 6 months
Car Model: MK 7 R
Membership No: 3011
Post by Vernon »
What is the total height of the disc itself and the thickness
ex
Blue Smurf (MK1 Chico Golf 2.1 L )
Silver Surfer (MK4 GTI)
Jeep Grand Cherokee SRT8
Present
@fearless_mk7R (VW Golf MK7 R )
AlexTDi
Membership No: 1724
Post by AlexTDi »
Vernon wrote:What is the total height of the disc itself and the thickness
280mm by either 18/20mm thick
Alex
Daily:
'15 6C Polo GTI DSG
Vernon
Car Model: MK 7 R
Membership No: 3011
Post by Vernon »
and the total height ?, why i'm asking is i have the powerbrake spitze disc and its height is 39,5 mm
ex
Present
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Correct , the disc we use have a total height of 39.5mm
8VALVE-zn
Registered for: 12 years 8 months
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Post by 8VALVE-zn »
Hi there Viper,
Could you be so kind to put up the 2016 price for these kits with extra bits for road & track use.
Thanks in advance.
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
8VALVE-zn wrote:Hi there Viper,
Thanks in advance.
Pryse have been updated on page 1
Genesisfs9
Car Model: Mk1 1.4 Carb
Post by Genesisfs9 »
Are there any kits available to change the back from drums to disks?
Viper
Goldwagen Delarey
Membership No: 1800
Re: RE: Re: 280mm bolt on Brake upgrade kits for MK1 is here!!!
Post by Viper »
Genesisfs9 wrote:Are there any kits available to change the back from drums to disks?
On witch vehicle?
Genesisfs9
Golf mk1 06
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
We use the mk3 rear brake setups. Straight bolt on. But rather spend the money on the front brakes, the rear shoes are more than sufficient even on track.
Genesisfs9
I was thinking on doing both the front and back or just the back to disks. I don't like the look of the drums makes the car look silly. I 'll start with the front I think. Also the hand brake doesnt hold the car very well.
How much is the mk3 setup and can I get it from you guys?
I 'll have to put the brakes on hold for a while. As my intake manifold sprung a leak and the thermoswitch is now broken as well. You guys stock the intake? My car has a carb.
Rathbone
Registered for: 4 years 9 months
Post by Rathbone »
Does anyone have a part number or at least have a year model number for me... nobody knows what im talking about... :mad: :bang:
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Rathbone wrote:Does anyone have a part number or at least have a year model number for me... nobody knows what im talking about... :mad: :bang:
You can contact me on 0824103147 for more details on this kit
Sent from my SM-G973F using Tapatalk
Rathbone
Post by Rathbone »
Ok thanks will contact you in the morning
Sent from my SM-A750F using Tapatalk
