Some radio logos updated/added. http://www.mediafire.com/file/a3zxm53pb ... 0.zip/filekripstoe wrote: ↑Sun Jun 23, 2013 2:16 pm I updated the radio station logos again. OCD. Was a little annoyed with the blocks around some logos and the quality thereof. So, I went to the German VW site to see exactly what size/bit level/transparency the logos are supposed to be (160x120, 32bit, .png, transparency allowed). I think these look a little better?
Golf 7 TSI/TDI Owners Discussion Corner
- kripstoe
- Membership No: 1379
Re: Golf 7 TSI/TDI Owners Discussion Corner
Current: '21 Audi 8V S3 Sedan S tronic
Ex: '15 Mk7 Golf 2.0 TSI Performance Pack DSG®
Ex: '13 Mk7 Golf 2.0 TDI Comfortline
Ex: '10 6R Polo 1.6 TDI Comfortline
Ex: '06 9N3 Polo 1.9 TDI Highline
Ex: '98 6N Polo 1.8i Lux
Ex: '96 Chico 1.3... it was green
Good day, I have tried reading these errors with some technicians they don't seem to solved what's amazing is at times the car will be fine and not have these. Permanent error that doesn't go away is Highbeam assist (where is the sensor location and how do I know if it's broken) also my aircon blows semi hot air I was told its high pressure sensor how do I test this? All of these events happen after I hit a stray animal. Also cigarette lighter doesn't work both of them. All fuses are OK. Please help
Sent from my BLA-L29 using Tapatalk
- Car Model: Golf MK7 '15
Hi, I'm new to the forum and I'm not sure if I'm posting to the right thread.
But I am currently in the market for a used golf mk7, what should I be looking out for and checking before committing to one?
- Car Model: MK7 GTI
Stay away from the 1.4 tsi especially if you don't know the history of the carD3s3mb3rg wrote:Hi, I'm new to the forum and I'm not sure if I'm posting to the right thread.
Sent from my SM-N960F using Tapatalk
MK7 GTI
Revo Tuned
Revo Intake
Roque Performance DP
Revo Tuned
Revo Intake
Thanks for the heads up, and anything with the TDI's?sbu.mah wrote: ↑Tue Feb 12, 2019 2:54 pmStay away from the 1.4 tsi especially if you don't know the history of the carD3s3mb3rg wrote:Hi, I'm new to the forum and I'm not sure if I'm posting to the right thread.
also what are the differences between the TSI's and the blue motion TSI's?
- Car Make: Vw, Bmw, Merc
- Car Model: 81 Vw Mk1 Cabrio,15 Mk7GTi
- Membership No: 3258
Howsit Guys
Reaching out to find out if anyone else ever had this issue on a VW Golf 7 GTi 2015
|Symptoms are random ,They could appear today and not tomorrow
- Power Steering gets heavy
-Start Stop Error
-Radiator Fan kicks in full blast ( The car could be ice cold at times)
Battery was tested and changed (19/03/2021)
Alternator to Body Ground Cable with Sensor was changed Twice
No lights on the dash
Car was scanned while fault was happening and we manged to get this code
Address 19: CAN Gateway Labels: 5Q0-907-530-V1.clb
Control Module Part Number: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component and/or Version: GW MQB High 128 1204
Software Coding: 030100042F085900EF00026A1C0F00010001050000000000000000000000
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_GatewLear 011020 (VW37)
ROD: EV_GatewLear_011.rod
VCID: 72BC24F8B429F0FBA15-8026
1 Fault Found:
8521278 - Battery terminal recognition
U1411 00 [009] - Open circuit
[Spannung Fahrbatterie mechanischer Fehler]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 166
Mileage: 173216 km
Date: 2022.02.02
Time: 14:32:21
Terminal 30 power supply: 14.4 V
Terminal 15: On
Wednesday,02,February,2022,15:01:08:27926
VCDS Version: Release 21.9.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 03: ABS Brakes Labels: 5Q0-907-379-IPB-V1.clb
Control Module Part Number: 3Q0 907 379 F HW: 3Q0 907 379 F
Component and/or Version: ESC H42 0609
Software Coding: 01FA93A13429297407800606C1C4A980C92C94E0608395F700420038C209
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027 (VW37)
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 3D26C7C4BDF77F838C7-8068
3 Faults Found:
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 203
Mileage: 173130 km
Date: 2022.02.01
Time: 00:08:35
-Start Stop Error
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 166
Mileage: 173216 km
Date: 2022.02.02
Time: 14:32:21
Terminal 15: On
www.Ross-Tech.com
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 203
Mileage: 173130 km
Date: 2022.02.01
Time: 00:08:35
