Gearbox oil level and capacity.
- Registered for: 21 years
- Car Make: Seat
- Car Model: Mk4 Ibiza FR 1.8 20VT
Hi guys!
A couple of weeks ago I replaced my speedo cable and now ive realised oil has been leaking from that hole where the speedo cable goes into the box. How do i check the oil level? and if i give the box an oil change, how much oil does it take? its an AUG gearbox originally out of a CTi.
thanx
thanx
2005 Seat Ibiza FR 1.8 20VT
1970 MGB GT Automatic
199X VW Citi Golf 1.3 aka "The Rollerskate"
- Car Make: No Cage
- Car Model: Only 2 Wheels
You need one moerse big allen key socket thing to loosen a big nut on the side of the gearbox! If you get the bolt out, stick your finger inside the hole (dont think naughty now) and you will feel the oil! If the level is level with the hole (allmost coming out) then its fine!
Sorry Im dutch, so my explanation isnt good
The lower you go, the more you break.
- Registered for: 22 years 10 months
- Car Make: SEAT
- Membership No: 478
Yip. You need a 17mm Allen key to loosen the plug on the side of the gearbox, then fill the gearbox up until the oil starts to drip out the side.
If the gearbox is empty, it will take 2l of gearbox oil to fill.
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- EX-DOHCTOR
- Registered for: 20 years 6 months
- Membership No: 712
There should be a rubber seal that goes under the metal plate that holds the speedo cable down.
Replace this seal aswell.
- Car Make: Seat
- MikeD
- MikeD
- Car Make: SEAT
Yip you fill from the hole where the speedo cable goes in, but you leave the plug on the side off so you can see when the box is full.MikeD wrote:you can also fill through the speedo cable opening.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- MikeD
MacMan wrote:Yip you fill from the hole where the speedo cable goes in, but you leave the plug on the side off so you can see when the box is full.MikeD wrote:you can also fill through the speedo cable opening.
U can use a bolt with a 17mm head, bend it to make a 17mm allen key.
Saves u buying a 17mm allen key
Current Car
05 Polo 1.9 TDI Sportline
96 CTI Golf - Upgraded to EFI , 272 Cam, 60mm Drop, Brospeed Branch, s/s f/f, brake upgrade
90 BMW 318i
90 BMW 318i
- Registered for: 21 years 4 months
MikeD wrote:![]()
Ford Ranger 2016
Hyundai Terracan 2005
Toyota Corolla 2011
Renault Megan Cabriolet
Mk1 2 door 1980
2008 Mazda 6 MPS.
Colt 2.4 Double Cab.
1.6 Polo 2003 Oo=w=oO (the love of my life)
1.6 Ford Bantam 1996
Ford Ranger 2016
Toyota Corolla 2011
Mk1 2 door 1980
2008 Mazda 6 MPS.
- MikeD
Or u just screw the nut onto a longish bolt ( R18 S N L VMikeD wrote:fatbastard wrote:MikeD wrote:![]()
This is what I meant:
Turbo-charged with a leafblower, Intercooled with a braai grill.
Sponsored by:
SMALLVILE COMICS (Alberton)
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
- MikeD
frog_in_the_fridge wrote:Or u just screw the nut onto a longish bolt ( R18 S N L V) and weld the nut to the bolt...just tack weld it. Then u can use a socket of the same size to loosen and tighten.
U could just use a second nut, as a lock nut system, no need to tack weld
Current Car
90 BMW 318i
90 BMW 318i
Lets make it freaky.....add another nut.MikeD wrote:now its "R- rated" two nuts
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
And how do u go about getting rid of all the old oil in the G-box....when u wana top up with fresh new oil?
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
- MikeD
Use the same mod allen key with "two nuts" and take out the plug at the bottom of the g-box.frog_in_the_fridge wrote:And how do u go about getting rid of all the old oil in the G-box....when u wana top up with fresh new oil?
Current Car
90 BMW 318i
90 BMW 318i
Cool.
Wots the best fully synthetic G-box oil? And how much oil does a FFZ box take?
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
- MikeD
Ok it will take just less than 2l of oil, but you will need to buy 2l.frog_in_the_fridge wrote:Cool.
U have a choice in oil, but I would recommend,
1. "G005000" oil from VW Agents - +/- R200.00 a L.
2. Castrol bot 130m or castrol SMX - at around R50.00 for 500ml.
Current Car
90 BMW 318i
90 BMW 318i
MikeD wrote:Ok it will take just less than 2l of oil, but you will need to buy 2l.frog_in_the_fridge wrote:Cool.
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Then can I add sum of that engine flush stuff...I know it makes ur oil very thin and watery for better removal?
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
- MikeD
frog_in_the_fridge wrote:Then can I add sum of that engine flush stuff...I know it makes ur oil very thin and watery for better removal?
I don't know about that!!! Sounds a bit dodge!
Current Car
90 BMW 318i
90 BMW 318i
Its like R50+- for 500ml of the stuff...at most garages. U pour it in b4 u service ur car...needa drive around a bit to get the oil warm and the stuff to work. Then when u drain ur oil....More comes out coz its watery....and not thick as usual
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
Sponsored by:
Joe Do Carmo
011 869 4904
083 534 9301
www.clickit.co.za
- Registered for: 19 years 1 month
- Car Make: VOLKSWAGEN
- Car Model: 2009 Citi Rox ABF
if it comes out thick, you got problems!!!!!!!frog_in_the_fridge wrote:Its like R50+- for 500ml of the stuff...at most garages. U pour it in b4 u service ur car...needa drive around a bit to get the oil warm and the stuff to work. Then when u drain ur oil....More comes out coz its watery....and not thick as usual
..../._____________.\.....
../( )====VW====( )\..
.|\_________________/|.
.|_\_______________/_|.
**2009 AB-EFF'd citi Rox**
