Hope ya'll well.
I need some help, I have a 2006 Polo 1.9 TDI 5Door and I've been trying to solve this issue for a while now,
My Speedo does not work along with ABS, Power steering, handbrake light turning on beeping.
Basically the car thinks it's not in motion as my launch control is now my limiter 4000rpm where as before when everything works it used to hardcut at 5000rpm
Also, it does not calculate the average fuel consumption and average speed on the cluster and the fuel gauge moves to empty and full when turning left/right
VCDS picked up the following errors
I changed the ABS pump and it still has the same issue.
Checked all fuses and they all good.
There is a sensor that sits on the top of the gearbox that I found was hanging out , from what I have researched is that this may be a speedo sensor
Could this be my issue?
Has anyone else had this issue before?
Any help will be greatly appreciated!
