Hi guys. I have a VW Golf Sonic with a 2E engine. I am experiencing problems with the gearbox where the oil is leaking between the spigot shaft and push rod on the clutch assembly. It caused the clutch to slip and totally destroyed the clutch. I did changed the clutch plate last year and also changed the small little brass bush and seal between the push rod and spigot shaft. Now that i took the gearbox out again i discovered that the seal fell out and there is a lot of sideways play between the push rod and spigot shaft. What would cause the premature wear of that brass bush ? Any ideas or something i can check ?
Thanks in advance.
Citi Golf Gearbox Push Rod Problems
- Tdi jetta 4 ever
Robin
robinwisse@gmail.com
- Tdi jetta 4 ever
Re: Citi Golf Gearbox Push Rod Problems
Any suggestions ?
Robin
Did you replace the release bearing inside the box when you did the other work?
When doing a clutch it's important to inspect and replace all the related components on an 020 gearbox. They really don't forgive cutting corners.
This time also inspect the plate the pushrod presses against. If the mark is misaligned it will need to be replaced. Try to get one with the "bearing" in it. Next up there are two methods to replace the release bearing, I prefer to unbolt the 5th gear cover. The bearing slides out, drop the new one in add sealer and put back the 6 bolts. The other method involves removing the green cap on the end, which damages the cap causing oil leaks. It also requires the clutch lever assembly to be dismantled to extract the bearing. It's fiddly and has many opportunities to make mistakes and create a new problem. The only time I recommend this is if there is a problem with the clutch lever mechanism.
So now you have serviced the release bearing and replaced the bushing, the tikkie seal and the pushrod. It's not always necessary but before installing the box, inspect the oil. I lost 2 boxes due to water ingress. Both had pinion bearing failure as a result of the water in the oil.
Sent from my 2107113SG using Tapatalk
- Tdi jetta 4 ever
Thanks for your reply Missioner. No last time i didn't replaced the release bearing. To my shock i compared the OD sizes of the old and new one and found that the old one was 32.5mm while the new one is 33mm so that also played a role. Yes the other problem was the plate where the push rod press against was mis aligned. This time i replaced everything. The whole clutch kit with a new Repco LUK one and new brass bush new push rod and also all oil seals including the crank seal. I also found out that the gearbox is a DGT code and to my knowledge its from a Jetta MK2.
Robin
I double up on those lousy small seals.
If one fails the other seals
Seems to work without any hassles
- Tdi jetta 4 ever
It exactly what i did. Somebody told me to do that so i did.
Robin
