CITI GOLF STEERING FEELS LOOSE
- Ryandevraj
- Car Model: 1988 Citi Golf 1.8
Howsit guys
So i need some advise on possible reasons why my steering feels loose and i have to keep correcting when driving the car on the highway. I have replaced the steering rack with a brand new original VW rack from Barons. I have replaced Tierod ends. The guys who did the allignment said my rack ends are still fine and theres no play in it.
Can worn ball joints cause the car to wander? and make the car feel light and loose on the steering.
Any help will be appreciated.
The car is a 1988 citi golf 1.8
- Car Make: SEAT
Re: CITI GOLF STEERING FEELS LOOSE
Yes. And worn wheel bearings.
and a broken hub could.
The knuckle on the steering column is loose or worn.
*Drops the mike and leaves*
Check the lower control arm rubbers and ensure the rear u-clamp that tightens to the floor board is tight.
- Ryandevraj
Ok so the check list for this weekend is , ball joints, LCA bushes,steering knuckle and wheel bearings. There is something weird though, after doing the rack it was fine for about a month. I made a turn and heard a "GUNG" type sound then turned the steering again and heard "GUNG". After that the issue started.
Did you check the 2 u-shape clamps that lock the steering rack in place, to the car ? Also check the general area that those clamps bolt onto as it may have torn away from the body of the car.
Hi is it ok to come back to the conversation?
That "gung" noise I've heard before, it was on a vehicle with bad shock top mounts. The top spring support wasn't turning with the shock and the steering and was locked/siezed to the top mounting that's bolted to the body.
As the steering turns the shock, the spring winds up until it overcomes the tension and jumps/turns inside the strut assembly, "GUNG!"
- Ryandevraj
This weekend has been rough, I havent had a chance to check anything as I got called in to work. Will check the shock mounts also tomorrow, Thanks guys
- Ryandevraj
@missioner, to update this post forever days later, you were right it was shock saddles
- Ryandevraj
There was no bearings, the previous owner literally removed everything, put nuts and then a lock not over. I replaced my steering rack and literally the whole suspension apart from that for nothing
- Car Make: ShitiGolf + CRX
On my wifes golf the low ball joints were super old and gave the steering a pretty loose feeling.
glad to helpRyandevraj wrote:@missioner, to update this post forever days later, you were right it was shock saddles
- Wolf Mk2 16V
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
