Radiator for Crossflow Throttles
- Rox_Star
- Wheel Whore
- Car Make: VW CITI Rox
- Car Model: Citi Rox 2l 8v
- Membership No: 1992
Hi Guys,
My first post and advice seeking mission.
Firstly I drive a Citi Rox, 2l 8v shortblock, stage 3 build by Sarel with single throttle.
Planning on going crossflow Throttles but I’m just having some issues around the radiator. I know cheaper ain’t always better but I just want to find out if any one here has dropped their standard radiator down to allow the trumpets to to get access to fresh air.
I have searched the forum, this topic has been discussed with regards to other radiator options, but I’m just checking if dropping the radiator is a good option. I trust Sarel but personally not sure if I want to cut the car yet.
Much appreciated guy.
__________________________________________
Citi Rox
2.0 8v Shortblock Crossflow Throttles
Built by 8v Performance
298cam, Branch, Exhaust, Diktator Management
110wkw 180nm
With some extra Peri Peri
Daily Driven
"Eat sum More"
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
Re: Radiator for Crossflow Throttles
i would like to know the answer too. Heard about this cut and drop too, but also very worried that it will weaken the front valance. It will definitely be weaker with the cut out unless the cut out gets boxed and welded up.Rox_Star wrote: ↑Sun Mar 04, 2018 9:32 pm Hi Guys,
- Registered for: 21 years 9 months
We cut a BMW 540 rad in half and mounted the halves behind each other with custom end tanks. Worked a charm.
- Rox_Star
- Wheel Whore
Thanks @Panic. Who did the tanks? Which model of 540 rad did you use? Thing is car is a daily so i sit in a bit of traffic everyday.
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
Great info, panicpanic-mechanic wrote: ↑Thu May 10, 2018 12:14 pm We cut a BMW 540 rad in half and mounted the halves behind each other with custom end tanks. Worked a charm.
Any chance of having a picture of this to give us an idea?
Oh gee no that was around 12 years ago - pics long gone. tanks were built by Aero tig in spartan but I believed he has also passed away since.
Was the first series 540 that came out. so would have been E39 I think?.
I was just the right length to fit snugly in the mk1's nose.
We ran small aftermarket fans and never had heat issues
- Rox_Star
- Wheel Whore
Ok thanks. Google says the E39 tank dimensions are 650mm x 440mm (L x H). This is the correct one right? So we cut it horizontally and get tanks make up for them after they stacked?panic-mechanic wrote: ↑Thu May 10, 2018 12:48 pm Oh gee no that was around 12 years ago - pics long gone. tanks were built by Aero tig in spartan but I believed he has also passed away since.
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
I have searched online and also came to the E39 model and dimensions you got. Looking at radiator flow characteristics then, I think this was made with an entry on the one tank, passing over on the tank on the other end tank to the other core and exiting on the other end tank in front of the tank where it entered. Motor side entered on the core closest to motor and return to head from the front core to prevent the hotter motor water coming out of motor to heat up the second core if second core was sitting at the motor side returning to head. Thermo switch then on bottom corner of end tank passing from one core to the other core.Rox_Star wrote: ↑Thu May 10, 2018 12:52 pmOk thanks. Google says the E39 tank dimensions are 650mm x 440mm (L x H). This is the correct one right? So we cut it horizontally and get tanks make up for them after they stacked?panic-mechanic wrote: ↑Thu May 10, 2018 12:48 pm Oh gee no that was around 12 years ago - pics long gone. tanks were built by Aero tig in spartan but I believed he has also passed away since.
Correct on the flow. Way too long ago for me to remeber dimensions
Thanks for confirming flow, panic.panic-mechanic wrote: ↑Fri May 11, 2018 11:12 am Correct on the flow. Way too long ago for me to remeber dimensions
Rox_Star had nmeasurements higher up in his post 650mm L x 440mm H. Cut in half then relate to 220mm H. Giving plenty free air space as the distance from bottom to top available is 330mm H (110mm open space).
- Rox_Star
- Wheel Whore
Do you know anyone in JHB who is good with custom tanks for Radiators? Still trying to find out who does these aluminum tanks.PapaJo wrote: ↑Fri May 11, 2018 2:30 pmThanks for confirming flow, panic.panic-mechanic wrote: ↑Fri May 11, 2018 11:12 am Correct on the flow. Way too long ago for me to remeber dimensions
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
No idea, who in JHB can help you.Rox_Star wrote: ↑Fri May 11, 2018 3:19 pmDo you know anyone in JHB who is good with custom tanks for Radiators? Still trying to find out who does these aluminum tanks.PapaJo wrote: ↑Fri May 11, 2018 2:30 pmThanks for confirming flow, panic.panic-mechanic wrote: ↑Fri May 11, 2018 11:12 am Correct on the flow. Way too long ago for me to remeber dimensions
Tell us in which area you are and someone can naybe assist in your area or point you to someone close to you.
you can try chris muller at CMS but he will be leaving the country soon.082 807 7209
- Rox_Star
- Wheel Whore
I’m in edenvale area.PapaJo wrote: ↑Fri May 11, 2018 4:21 pmNo idea, who in JHB can help you.Rox_Star wrote: ↑Fri May 11, 2018 3:19 pmDo you know anyone in JHB who is good with custom tanks for Radiators? Still trying to find out who does these aluminum tanks.PapaJo wrote: ↑Fri May 11, 2018 2:30 pmThanks for confirming flow, panic.panic-mechanic wrote: ↑Fri May 11, 2018 11:12 am Correct on the flow. Way too long ago for me to remeber dimensions
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
- Armand
- Car Model: Black Magic 6R Polo Gti
- Membership No: 1828
What type of radiator do they use for side conversion?
2009 Citi 1.4i sport
Bmw 540i e34 (Standard)
2009 Polo gti (Giac software)
- Car Model: VW Caddy 2K 2.0 8v
My friend also uses a Honda radiator, the one with a dual core I think.
- Rox_Star
- Wheel Whore
Does it work well in traffic?
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
No overheating at all!
- MarshallGTi
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
Hetdre radiators in Meyerton does great tank fabrication
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ok, thats in my town. Will find them.MarshallGTi wrote: ↑Tue May 15, 2018 4:50 pm Hetdre radiators in Meyerton does great tank fabrication
- Rox_Star
- Wheel Whore
Please keep us informed on how it goes and if u win withthe design and fitPapaJo wrote: ↑Tue May 15, 2018 8:11 pmOk, thats in my town. Will find them.MarshallGTi wrote: ↑Tue May 15, 2018 4:50 pm Hetdre radiators in Meyerton does great tank fabrication
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
Citi Rox
110wkw 180nm
Daily Driven
"Eat sum More"
Ok, will do.
- Old School Quintin
- Registered for: 10 years 9 months
- Car Model: MK1 16v
Any news on the build and what radiator was used
2008 VW CitiRox
Abf 45mm ITB
Under construction
Seeking ponies
Abf 45mm ITB
Under construction
Seeking ponies
