280mm bolt on Brake upgrade kits for MK1 is here!!!
I didn't buy the calipers from them just the disks and spacers, I don't mind if I have to buy new calipers it's just I need to get this sorted ASAP
The kit is designed for a citi and to work with stock calipers.
Go see them on Tuesday and I am sure they can get you sorted out.
- Goldwagen Delarey
- Registered for: 14 years 4 months
- Membership No: 1800
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Check that the mounting points on the hub carriers are straight and not bent in or out.
These things:
These things:
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- Goldwagen Delarey
All sorted out. He was here this morning with everything . His calipers are aftermarket pirate once and the brackets crossing the discs is thicker . So with the std 237mm it doesn't matter but with the 280mm discs the larger diameter is just to much. We took the pencil grinder to it and cleared just enough the give the discs some space. So now we know that there are some clearance issues with the aftermarket calipers .Kyli3boi wrote:Hi,
- Car Model: MK 7 R
- Membership No: 3011
What is the total height of the disc itself and the thickness
ex
Blue Smurf (MK1 Chico Golf 2.1 L )
Silver Surfer (MK4 GTI)
Jeep Grand Cherokee SRT8
Present
@fearless_mk7R (VW Golf MK7 R )
Present
- AlexTDi
280mm by either 18/20mm thickVernon wrote:What is the total height of the disc itself and the thickness
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- Car Model: MK 7 R
and the total height ?, why i'm asking is i have the powerbrake spitze disc and its height is 39,5 mmAlexTDi wrote:280mm by either 18/20mm thickVernon wrote:What is the total height of the disc itself and the thickness
ex
Present
Present
- Goldwagen Delarey
Correct , the disc we use have a total height of 39.5mmVernon wrote:and the total height ?, why i'm asking is i have the powerbrake spitze disc and its height is 39,5 mmAlexTDi wrote:280mm by either 18/20mm thickVernon wrote:What is the total height of the disc itself and the thickness
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Hi there Viper,
Could you be so kind to put up the 2016 price for these kits with extra bits for road & track use.
Thanks in advance.
Thanks in advance.
- Goldwagen Delarey
Pryse have been updated on page 18VALVE-zn wrote:Hi there Viper,
Thanks in advance.
- Genesisfs9
- Car Model: Mk1 1.4 Carb
Are there any kits available to change the back from drums to disks?
- Goldwagen Delarey
Re: RE: Re: 280mm bolt on Brake upgrade kits for MK1 is here!!!
On witch vehicle?Genesisfs9 wrote:Are there any kits available to change the back from drums to disks?
- Genesisfs9
- Goldwagen Delarey
We use the mk3 rear brake setups. Straight bolt on. But rather spend the money on the front brakes, the rear shoes are more than sufficient even on track.
- Genesisfs9
I was thinking on doing both the front and back or just the back to disks. I don't like the look of the drums makes the car look silly. I 'll start with the front I think. Also the hand brake doesnt hold the car very well.
How much is the mk3 setup and can I get it from you guys?
I 'll have to put the brakes on hold for a while. As my intake manifold sprung a leak and the thermoswitch is now broken as well. You guys stock the intake? My car has a carb.
Does anyone have a part number or at least have a year model number for me... nobody knows what im talking about...
- Goldwagen Delarey
You can contact me on 0824103147 for more details on this kitRathbone wrote:Does anyone have a part number or at least have a year model number for me... nobody knows what im talking about...![]()
Sent from my SM-G973F using Tapatalk
Ok thanks will contact you in the morning
Sent from my SM-A750F using Tapatalk
