Skimming the head for 288 cam
Servicing and repairs on all VW and Audi models, old and new. The passion is sort of on the old but we also love the newer and can do whatever you need.
raveennaidoo3
Post by raveennaidoo3 » Thu Dec 29, 2016 7:37 pm
Hello there. I have a vw 2L8v agg engine running on Dictator with the head flowed, std valves and 282 cam.head is skimmed 0.5mm.
Read on the forum that you have to skim over 1mm to use 288 cam.is this necessary? Can I leave my head at 0.5mm and use the 288 cam.my car is a daily driven car
Sent from my E2303 using Tapatalk
JonaDTD
Car Model: 2.0 8V
Re: Skimming the head for 288 cam
Post by JonaDTD » Fri Dec 30, 2016 2:43 pm
Will fit on AGG
I'm running one without problems
Lemon Citi Ride Thread:
1995 Citi - 2.0 8v, headwork, double valve springs, Estas 288, bigger valves, Dicktator, 4-2-1 branch, 50-57mm progressive exhaust.
Ex ladies:
Polo TDi Sportline 2008 9n3 - GTB2268VK, FMIC, Fuel Cooler, A/C Delete, Interior Delete, Sparco Deep Dish Wheel, 12.9 Head Bolts, Race Pipe, 63mm Exhaust, Full Poly Mounts, Coilovers, blah blah blah. Ride Thread Here: SR Tuned BT TDi
Polo 2.0 Highline 9n3 (90kw 175nm) SOLD
Ford Fiesta 1.6 TDCi (RIP)
raveennaidoo3
Post by raveennaidoo3 » Fri Dec 30, 2016 3:54 pm
Did you have to clear the head for the 288 to clear
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner » Sat Dec 31, 2016 6:58 am
Skimming the head bumps the compression up for better performance. The cam can run in a standard head without problems, nowhere does it say that skimming a head is mandatory in order to run a warm camshaft.
OP you need to read up on static vs dynamic compression and how they affect your engine.
BlueBlob
Post by BlueBlob » Sun Jan 01, 2017 10:50 am
raveennaidoo3 wrote:Did you have to clear the head for the 288 to clear
That's only an issue with the 298's.
