Dawie wrote:Looking good there rpps. I just fitted my polished chrome exhaust tips from VW. Not 100% happy with the fit but will play around some more with placement. I see your after market ones protrude quite far out.
Thanks I'm getting there with the car, yeah the tips do stick out a bit but I like them to protrude a bit out past the bumper, I could shorten them up if I wanted.. I had trouble fitting these after market tips which I got from the local Repco auto shop, I had to make up sleeves to fit over the exhaust to take up the slack. It seems that the exhaust pipe VW use isn't a common size and it was hard finding the right diameter tip, these were 63mm where it fits onto the original exhaust and 75mm at the other end. Which is a bit bigger than the genuine ones but looking from behind the car all you see is these nice big round pipes and they look good, better than what I thought chrome exhaust tips would.
Now anxiously waiting for my dash mat to arrive this week and then I'm done for a while
http://www.accessoriesonline.com.au/sho ... featured=Y
After fitting the new Alloy wheels I have noticed a slight vibration through the car, apparently one of my tyres is slightly out of round (Goodyear) but I stuck it on the back and I will replace in time, I couldn't be bothered with the hassle of claiming warranty with it.
I only have the Radio to be fix now and hopefully I soon will be able to pick up FM reception better, I'm keeping a close eye on this forum for any news about the upcoming software update and the results.
