DIY polo 9n3 swg pod + boost gauge fitment
Post by dood786 »
Firstly, massive thanx to Shaun from VagTechnik for finally bringing in these pods, I nagged him for a while, the costs did climb rapidly but he did it. They are available from VagTechnik for R850 each, only 4 left
The pod seems to be a fibre glass mould, it is an insert only
Gauge chosen is the Podi mechanical gauge
Actual
The kit that comes with it comes with these accessories
The rear of the guage has this copper tap for the boost pressure feed
You need to start by removing the driver side vent.
Remove the cover to the fuse box, then with a slight bit of force, push the bottom of the vent outwards, you may need to insert a screwdriver to help you lift it out. There are 4 silver clips holding the vent into the dash as seen in the pics below
As you slowly pull the vent out, careful as the air guide behind it is loose and just hooks into place
The vent is fragile so be careful
Once the vent is out, you need to strip it into separate pieces
This is the bottom view
You need to get the silver trim off first, 3 clips per side and 2 at the top
Once open, you may remove the front fins
Test fitting the insert
I then removed the vertical slats too
You now need to drill a hole into the bottom of the vent to allow wiring and piping to come through
I started with an awesome litle hole, it was so neat, thenm i looked and the wiring harness and realised only 1 wire would fit through, so i needed to butcher it and make a larger hole, it eventually grew into 1 large hole with an additional section beside it for perfect snug fitment
You will notice that the hole is almost in the centre, you can move it to where you please, however the instructions advise to ensure vent remains closed at all times
My solution to this was to disconnect the opening arm completely
The boost pipe needs to be tapped, i chose the pipe beside the FPR
Boost tap - I forgot to take that pic so im using the one off the diy thread below
The pipe was then run to the rear of the engine bay, below the ecu is a grommet(the only actual place you can use from my findings) which comes out at the passenger footwell. I ran the pipe through a gap behind the centre console and this feeds into the vent from under the dash, pipe is a bit long so can be trimmed for perfect fitment or tucked
Now for the wiring, as you saw, there are just 2 wires, white and black
White is for illumination, which i tapped from my ignition wire
You firstly need to remove the entire switch, to do this, you push the switch in and twist clockwise and the entire switch comes out
You need to tap into the grey/white and blue wire, 2nd from top
The black wire is ground, so I just stuck it under the screw holding the fuse box in place
The globe is just a push in, I only got white and red, will try get hold of the vw match blue
Testing the light
Vent fitted back in
Now you just plug the light into the back of the guage, connect boost tap to copper connector and done
Final product
Tips and advice was taken from these links HERE and HERE
Short video
Note the guage is in psi, not bar
10 psi = 0.69bar so when it hits 20 psi, its 1.38bar
Photobucket
Youtube
http://www.youtube.com/watch?v=Bx6M2YmIMQE
Vimeo
http://vimeo.com/24073256
MeanTdi
The Imposer Mod-whore-rator
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Re: DIY polo 9n3 swg pod + boost guage fitment
Post by MeanTdi »
Great DIY Dood! Looking good man.
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Post by dood786 »
Thanx
StealthGTi
Car Make: ...None
Car Model: ..... None
Post by StealthGTi »
Thanx Dood, Very nice DIY.
Congrats man.
SemiColon
I sparkle in the sunlight
Car Make: Volvo
Car Model: S40 T5
Membership No: 1641
Post by SemiColon »
Nice"
Will this make my 1.6 faster?
八拾六
jk
Registered for: 19 years 11 months
Post by jk »
Night pics?
Amith11
Car Make: DUH !!!
Car Model: MK7 GTI
Membership No: 1545
Post by Amith11 »
Nice DIY Naseem...
MK 7 GTi
(Daily)
amith.singh@icloud.com
Lost Loves:
Mk4 Tdi Wagon
MK4 TDi
Mk4 GTI .:R (True Love)
MK3 Cabriolette 2.0l Exec
Mk2 GTI 1.8 8V
Mk1 Caddy
Mk1 GTS (4door)
Tander
Car Model: Leon Cupra
Membership No: 1713
Post by Tander »
SemiColon wrote:Nice"
Don't you already have a turbo on your 1.6?
Exes:
2006 Polo 9N3 - 1.6i
2003 Citi.com 1.3
2003 Opel Corsa Lite
Crawler
Car Model: 9N3 Polo TDi
Membership No: 1358
Post by Crawler »
thx for taking time, looks great
CW Polo TDi Sportline
SemiColon
Car Make: Volvo
Car Model: S40 T5
Membership No: 1641
Post by SemiColon »
i wish... :grin:
八拾六
Post by dood786 »
Thanx
Night pic
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
Great work Naseem :wink: I cannot see any of the pictures, but I presume that you executed teh DIY with the precision that is to be expected from a terrorist...
Post by dood786 »
I tried my best
MeanTdi
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Post by MeanTdi »
dood786 wrote:Thanx
Night pic
*snip*
Do you have a pic from further back showing the boost gauge and the speedo? Want to see the whole colour scheme on the dash board.
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Post by dood786 »
Nope, will try take one, but I need to get a blue globe, friend offered me one which I will collect soon, then it will match the dashboard
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
dood786 wrote:I tried my best
That will have to do, as a terrorist it's not like you getting a second chance...
Post by dood786 »
Yep, I usually finish with a bang
jk
Post by jk »
The South gauges are blue right? Will still fit in this housing?
Post by dood786 »
Any 52mm guage will work
Post by dood786 »
