9N Rear Brake pad change
EX-DOHCTOR
Membership No: 712
Post by EX-DOHCTOR »
Right, so I need to do the rear pads and possibly the rear discs aswell.
I know that I can use a g-clamp and a pair of circlip pliers to turn the rear piston back into the caliper, so that part shouldn't be a problem.
Just wanted to find out if there are any other hassles I should be aware of before I yank everything off on Sunday morning?
Any advise welcome.
TIA :hi:
Re: 9N Rear Brake pad change
Post by dood786 »
I remember reading that you need a special tool as the g clamp doesnt allow you to rotate the piston?
MK2 G60
Membership No: 388
Post by MK2 G60 »
Just push and turn mate.With correct tools.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
EX-DOHCTOR
Membership No: 712
g60 golf wrote:Just push and turn mate.With correct tools.
You wouldn't by any chance be able to lend me this tool?
I'll give you a call later :hi:
EX-DOHCTOR
Membership No: 712
dood786 wrote:I remember reading that you need a special tool as the g clamp doesnt allow you to rotate the piston?
The 9N Haynes manual reckons you turn the piston while the g-clamp is being tightened, it's a two person job using that method. I know some of the challenge guys also use this method to do their rear brakes.
Sinbad
Car Make: Mercedes
Car Model: R170 AMG Hairdryer
Membership No: 1152
Post by Sinbad »
If you don't come right you're welcome to pop round my place one afternoon and I'll help you out
Post by dood786 »
Sinbad wrote:If you don't come right you're welcome to pop round my place one afternoon and I'll help you out
I might just take you up on that too
MikeD
Registered for: 18 years 2 months
Post by MikeD »
Oh boy, I have tried it and didn't succeed!
There is a special tool you will need and trust me if you dont have it or have a trick up your sleeve,
your not going to get it off!!!
Will try and find the other post that I had this discussion in.
Good luck buddy!!!!! your gonna need it! :evil:
Current Car
05 Polo 1.9 TDI Sportline
96 CTI Golf - Upgraded to EFI , 272 Cam, 60mm Drop, Brospeed Branch, s/s f/f, brake upgrade
90 BMW 318i
MikeD
Post by MikeD »
Current Car
90 BMW 318i
EX-DOHCTOR
Membership No: 712
Hmmm... might need to reconsider this.
MikeD
Post by MikeD »
EX-DOHCTOR wrote:Hmmm... might need to reconsider this.
Oh come on now, at least give it a go for yourself.
You might have a better technique than I had when I tried.
The worst that can happen is you fail and have to tighten it back on…
Try it! :razz:
Current Car
90 BMW 318i
EX-DOHCTOR
Membership No: 712
Right, giving it a bash on Sunday morning with a mate. He's a Merc mechanic and has the tool I need to turn the piston in on the rear calipers, great success!
:grin:
EX-DOHCTOR
Membership No: 712
Right, so the rear discs were fine, we only changed the pads. Whole job took no more than 30 minutes and no "special tool" was required to get the job done. Just a pair of water pump pliers and a socket extension bar :lol:
Gonna take the discs back to GW for a credit :P
Great success!
Tdi jetta 4 ever
Post by Tdi jetta 4 ever »
Explain in detail if you don't mind I don't understand the socket extension part?
Robin
robinwisse@gmail.com
EX-DOHCTOR
Membership No: 712
Most socket wrenches have a long and a short extension that you connect to the socket wrench and then connect the socket onto. You'll obviously use the long extension for this job :wink:
So basically, once you've removed the lower bolt of the caliper and brake pads. You slide the extension through the caliper and push it up against the piston, then, using the water pump pliers you'll turn the piston while pushing against it with the extension bar. So simple and quick, yo9u could do it by yourself :grin:
"Special Tool" se gat! :lol:
Tdi jetta 4 ever
O.K thanks, will try it next time.
Robin
Zaleeu
Registered for: 10 years
Car Model: 9N Polo Sedan 1.6
Post by Zaleeu »
Jeesh Guys,
This stupid system has me licked. I tried turning and pushing this caliper in and it just wont budge.
Pliers and g-clamp se moer . It does not move. Do you guys remove the handbrake cable and open the bleeder ?
Any advice ? Before I get the BIG hammer :) lol
Polo 2006 9N Trendline
Stefan0909
Car Model: Tiguan 2.0TDI
Post by Stefan0909 »
Zaleeu wrote: Wed Apr 17, 2019 7:20 am Jeesh Guys,
No need to remove HB cable.
Just turn it into a opposite direction and try then.
Citroen and Peugeot is the same.
Waterpomp tang en G klamp and patience
1.4i Velocity Stock
1.4i Kia Rio Stock
1.8i VTEC Honda FRV Stock
Citroen DS3 Techno Pack Stock
ICE King
Post by ICE King »
Turn clockwise for the piston to go down and anti clockwise to turn up - I used a long nose pliers and held the caliper against the shock however had to remove the HB cable from the caliper
If you do struggle , open bleeder valve and piston will easily turn however a full bleed will need to be done afterwards.
Or simply buy the correct rewind tool. Most decent spares shops stock them or take it somewhere which has the rewind tool.
ICE King
Post by ICE King »
+1 what panic said if you can find one, I struggled trying to find the tool and when I did , shops wanted an arm and a leg
Resorted to the mentioned method above and worked for me although would've be way easier if I had the tool
NOTE:
by trying to force the rear caliper piston(w/handbrake) down with a g clamp without turning the piston will damage it.
You a use the g clamp to push down on the front calipers.
Be careful that you don't damaged the piston rubber boot
Howie-WP
Membership No: 2033
Post by Howie-WP »
ICE King wrote: Wed Apr 17, 2019 10:11 am +1 what panic said if you can find one, I struggled trying to find the tool and when I did , shops wanted an arm and a leg
Adendorff has them for R350..... https://www.adendorff.co.za/product/mac ... back-tool/
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
OP, @EX-DOHCTOR, did you get your credit from Goldwagen? Please respond urgently!
ICE King
Post by ICE King »
Howie-WP wrote: Wed Apr 17, 2019 11:19 am
Thanks Howie :thumbup: , half the price of what they asking in the southern suburbs, rather that than having the pliers slip and ending up with a bigger problem.
OettingerTDi
Registered for: 19 years 5 months
Car Model: Touareg / Caddy / Polo / Citi
Post by OettingerTDi »
Something else to bear in mind...
If you have the pads and don't want to get dirty, pop over to your closest Supa-Quick, they will sort you out for a reasonable fee.
I learnt the painful and frustrating way, and ended up buying the 21 piece kit, now its a breeze.
Anton van Graan
2009 Touareg 3.6 VR6
2007 Caddy Life 1.9 TDi
2004 Polo 1.6 Comfortline
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
1988 Ford Laser 1600i Sport
