Who here wishes their 5th gear ratio was higher?
I have spoken to a few mates with VW's (Mk4 golf, Mk3 golf, Polo etc) and they agree when you're cruising on the highway, the difference between 4th gear and 5th gear is not quite as much as we'd like! I feel it would be much nicer to have a "longer" (for lack of correct terminology) 5th gear so my car wouldn't rev so high on the highway. It sits at about 3000rpm at 120kmph.
Does anyone else experience this and I wonder if there is any way to rectify it?
There is a difference between wanting a longer fifth and your car being actually able to use it. If you are running a 1.6 or so a longer fifth migh actally be worse for consumption and now you will have to use 4th on uphills all the time. If you have a motor that is very torquey like a 2l or so and it can oull a longer fith - sure all you need to do is pull off the gearbox end casing and change it. Can be done without even taking the box out.
- General
- Car Model: Golf 7R
Re: Who here wishes their 5th gear ratio was higher?
Dude u should be happy with that, my car sits at 100km/h @ 3000rpmmatt wrote:It sits at about 3000rpm at 120kmph.
- Neuk
- Treasurer
- Membership No: 806
I don't - He He Gotta love 6 speeds
I have a '01 1.8 Polo Playa - I think it could definitely handle a longer 5th gear. Would it be very expensive to change?panic-mechanic wrote:There is a difference between wanting a longer fifth and your car being actually able to use it. If you are running a 1.6 or so a longer fifth migh actally be worse for consumption and now you will have to use 4th on uphills all the time. If you have a motor that is very torquey like a 2l or so and it can oull a longer fith - sure all you need to do is pull off the gearbox end casing and change it. Can be done without even taking the box out.
- nick
- Neuk
- Treasurer
True, true 120 km/h is at around 2200rpm IIRC - nice and economicalSokar wrote:You have 6 speeds because your ratios are so short to use the torque a diesel givesNeuk wrote:I don't - He He Gotta love 6 speeds
Otherwise you would be doing 80 in 5th
- Sacrilege
- Car Make: Ford
- Car Model: Ranchero '97 4.0i Vanderlinde
- Registered for: 20 years
- Membership No: 731
dude the tdi ratios are actually LONG!
i think 4000rpm in 6th is like 210km/h. Imagine that ratio in a petrol....and being able to rev that to 6-7000rpm!!!
Stuart
2006 Jeep Wrangler "Sarge"
1966 Splitty.
2014 KTM 1190 Adventure
No Mk1 ;(
1966 Splitty.
No Mk1 ;(
- Colonel
Be happy you sit at 3k at 120, in the jetta I sit at 3500 at 120 ?? 5th Gear ratio is .91
I've organised a .85 (I think?) just got to get time to swap it with the "donor"
- General
- Car Model: Golf GT
- Membership No: 1464
I remember the 1st Jetta 1's that came out with a 5-speed 'box had a 4+E configuration, 120 in 5th gear worked out to about 2200 rpm. The E stood for economy, not good for anything else tho!
Current rides:
Hyundai - 1.4 Getz (daily)
- Abnormal
- Membership No: 848
I think i had a box similar to that in my previous CtiTorker wrote:I remember the 1st Jetta 1's that came out with a 5-speed 'box had a 4+E configuration, 120 in 5th gear worked out to about 2200 rpm. The E stood for economy, not good for anything else tho!
It used to do 200km/h in 4 at the redline... then i could change to 5th... and well slow down.... (wasnt that bad really)
on a down hill... (from beyers to hans strydom offramp) it could easily get the speedo needle to hit the odo reset button on the bottom of the clock.
Could pass many cars on topend...
- Colonel
On the way to work this morning ... just saw the MFA still pretty economical
- Registered for: 19 years 11 months
I have a 2006 Caddy 1.9 Tdi
At 3000RPM in 5th gear I am doing 150 Kms/h.
Please if anyone here has the same vehicle can you tell me what yours is doing.
