MK6 Jetta 1.6 TDi Limp home mode and P0087 code
LengaMK6TDI
Registered for: 2 years 3 months
Car Make: VW Jetta
Car Model: MK6 1.6TDi
Post by LengaMK6TDI »
Hello guys,
I need your help. I have a 2016 MK6 Jetta, 1.6 TFi with 186k on the clock. The car started giving me a P0087 code, pretty common code which is a low fuel pressure on the common rail.
I replaced the pressure sensor to make sure it wasn’t faulty, had the HPFP and injectors tested. One injector had too much leak back so the injectors were cleaned and it was replaced
. Problem still persists and the common rail was switched with and the problem remained, so it’s not the pressure regulator either. The tests showed that the pump gives out 250 bar but the pressure fluctuates a lot. The car was tested at various diesel places and dealers in both Namibia and Cape Town bit so far JP one could solve this issue.
This limp home problem is worse when the car is hot and I also noticed that out of nowhere the ideal will just go to 1000rpm and the car would pulsate, then minutes later it’s back to 900rpm. The car vibrates slightly when you idle and this isn’t all the time either.
I’m really out of options as to what else could be wrong. Someone told me that it could be a software issue, anyone had that experience before? I’m considering also removing the CAT, cause I suspect that’s blocked too at this mileage now. Important to note that is that this problem hardly occurs when the weather is cold, but when it’s hot it’s worse, also that when it goes into limp mode, it momentarily lose power like you feel it but then you can still drive to over 2000rpm where the limp mode normally occurs. I’m blurping here but you can tell the desperation to have answers, please help. Thank you
THANAS
Car Model: AW Polo GTi
Membership No: 2035
Re: MK6 Jetta 1.6 TDi Limp home mode and P0087 code
Post by THANAS »
Hi, you can give us a shout on O84 452 419O, or via email on michael@thanas.co.za. We're based in Cape Town and specialise in hard to solve problems.
J0NN0
Registered for: 12 years 2 months
Car Make: No Name
Car Model: Tekkies
Membership No: 1725
Post by J0NN0 »
Topic moved to correct section
Jonno
2002 Volkswagen Lupo 1.4TDI - SAC: 87.7 kw 276.1nm
2018 Mitsubishi Triton 2.4 D/C 4x4
2006 Mitsubishi Colt Clubcab 2800 TDI
2003 Volkswagen Lupo 1.4 16v Auto
2007 SEAT LEON FR
1983 Volkswagen Caddy - Panic: 319.7hp 360nm
2008 SEAT LEON CUPRA - Oettinger: 191kw 352nm
2008 SEAT IBIZA CUPRA - HM Auto: 146.9hp 244nm
2007 SEAT LEON FR - KAR: 163.2kw 337nm
2007 Volkswagen Polo 1.6
2001 Ford Fiesta Flite 1.4i
VWCSA Membership Number: 1725
LengaMK6TDI
Car Make: VW Jetta
Okay guys so this is sorted out. the problem was that the fuel lines on the fuel filter housing were swopped. The return from the common rail and the fuel feed line that connects to the metering valve on the high pressure pump. Lines out back on their respective ports and bang, this baby once again drives like she just rolled out of the assembly line.
Anywho, I am planning to do a CAT delete and a stage 1 software tune, anyone done this on a 1.6 TDi here to tell me how they respond? Also suggest reputable diesel tuners in Cape Town.
DotDubb
Can I buy your wheels?
Car Make: Audi A6 3.0T
Car Model: DKW, Cabrio, A6 avant,Mk2
Membership No: 1593
Post by DotDubb »
LengaMK6TDI wrote: Thu Dec 02, 2021 9:38 am Okay guys so this is sorted out. the problem was that the fuel lines on the fuel filter housing were swopped. The return from the common rail and the fuel feed line that connects to the metering valve on the high pressure pump. Lines out back on their respective ports and bang, this baby once again drives like she just rolled out of the assembly line.
Speak to Thanas as per his message, he does software tuning and he tuned all my cars.
THANAS wrote: Tue Nov 30, 2021 10:09 pm Hi, you can give us a shout on O84 452 419O, or via email on michael@thanas.co.za. We're based in Cape Town and specialise in hard to solve problems.
1991 Golf Mk2 1.8 20vT
1960 Autounion DKW 1000s
