Dicktator management firing but engine is not running
Deanou213
Registered for: 2 years 5 months
Car Model: Caddy 1.8i,Microbus,Audi 3.2
Post by Deanou213 »
Good day all
I have a really huge problem on my vw caddy pickup with a 1.8i motor And dicktator management.
Car was driving fine till I parked it my friend's house and the rats decided to eat the wires (wires going to the ignition coil mostly affected).without knowing I started the car and car wouldn't start only to find wires where eaten and exposed to each other.
Got new wiring fitted and took it to a local dyno shop for a new map.
Car starts but when revving it cuts it self off and the coil wire from the ignition coil to distributor cap keeps firing spark ,green and orange light on the dicktator keep flashing,relay makes a flickering sound all these happens after a ugly start up then engine just cuts off but all this happens.
I would appreciate any help
Quik-Trix
Membership No: 3004
Re: Dicktator management firing but engine is not running
Post by Quik-Trix »
You running a TP100 Module ?
Deanou213
Post by Deanou213 »
No. It has no module
Quik-Trix
Membership No: 3004
Post by Quik-Trix »
So using the 3 pin MP9 Coil ?
Deanou213
Post by Deanou213 »
Correct
Quik-Trix
Membership No: 3004
Post by Quik-Trix »
is it wired with TPS or MAP Sensor? if MAP, Check the Vacuum hose going to the ECU, Incase the Rats had dessert there
