hi everyone i have a golf velocity 1.4 and i have a problem with one of my headlights....
when i switch on my lights then only the right headlight go on but when i switch on the brights then everything works even the left headlight.
im so confused, can anyone help plz.
left headlight issue
- Car Model: Mk5 Golf GTI
Re: left headlight issue
Firstly check the bulbs and then check the plug with a multimeter to confirm there is power to switch switch on the bulb.
If it is a combined bulb, it wil have 3 pins. 1 common connector and 1 pin for either dip or brights.
Measure the working light plug with the multimeter ND then do the same for the one giving you hassles. You should be able to confirm if there is power on both pins that way.
Sent from my SM-N770F using Tapatalk
Last edited by theunis.visser on Thu Oct 14, 2021 11:23 am, edited 1 time in total.
thank you ill try that asap
