Good day
I am having a vw polo TSI CJZ engine, it has cooling system problem only when speeding but when driving at a lower speed it does not overheat, I have changed the water bottle and cap, water pump and the coolant pump but stil overheat ( it only over heat when speeding, when stationary it doesn't)
Vw polo TSI overheating
- J0NN0
- Moderator
- Car Make: No Name
- Car Model: Tekkies
- Membership No: 1725
Re: Vw polo TSI overheating
Topic moved to correct section
Jonno
2002 Volkswagen Lupo 1.4TDI - SAC: 87.7 kw 276.1nm
2018 Mitsubishi Triton 2.4 D/C 4x4
2006 Mitsubishi Colt Clubcab 2800 TDI
2003 Volkswagen Lupo 1.4 16v Auto
2007 SEAT LEON FR
1983 Volkswagen Caddy - Panic: 319.7hp 360nm
2008 SEAT LEON CUPRA - Oettinger: 191kw 352nm
2008 SEAT IBIZA CUPRA - HM Auto: 146.9hp 244nm
2007 SEAT LEON FR - KAR: 163.2kw 337nm
2007 Volkswagen Polo 1.6
2001 Ford Fiesta Flite 1.4i
VWCSA Membership Number: 1725
2007 SEAT LEON FR
When diagnosing it, it says Cooler dry running, I have changed coolant pump, water pump, two temperature switches, water bottle and cap
- Car Model: Cti
- Membership No: 2095
Is the water level running low?
My wife's car had an issue about a year or 2 ago - there's an auxiliary cooler which is kinda behind the bottom grill. This got pierced and the car ended up losing water, resulting in it starting to heat up. Thankfully we found it in time and managed to get it sorted.
viewtopic.php?f=94&t=216654&p=2594138#p2594138
Hope this helps.
Hope this helps.
Good evening
I have replaced the auxiliary pump... Stil the problem is not solved... Funny part is that it only overheat when driving at a higher speed... When driving in a traffic it does not overheat
Online
Are you sure that there's nothing blocking airflow to the radiator? Packet or some other debri thats behind the grille somewhere?
The is nothing I also removed the front bumper, removed the radiator and tried to clean it but the problem is not solved
- Registered for: 3 years 2 months
Just wanted to know if VW has voided any warranties due to decatting because I would like to decat my car but it’s still under warranty
2 thingsbyro wrote:Just wanted to know if VW has voided any warranties due to decatting because I would like to decat my car but it’s still under warranty
Thread hijacking is rude.
Yes decat will void your warranty.
Any results on this post I'm having same problems
