1.4 TSI Low oil pressure
- Registered for: 2 years 7 months
Hi All,
We have been having trouble finding a fault. We have a 2011 1.4TSI Golf 6. The engine was redone pretty much replacing everything.
Big end bearing
Valve guides
New timing chain kit
New oil pump due to trying to fault find.
The list goes on.
All ports are clean and there doesn’t seem to be any cracks or leaks anywhere we can see. All bearings have been tested and are perfectly to spec.
From cold start the pressure is 1.5 bar once at running temp the pressure dips. We have tested it with a mechanical gauge and it drops below 0.4 at running temp.
I have seen a lot of post with the same problem but no solutions.
We are at a loss. We replace everything we could think of and the exercise has become very costly.
Has anyone had this issue and been able to fix the problem.
Any advice would be appreciated.
Big end bearing
Valve guides
The list goes on.
Re: 1.4 TSI Low oil pressure
Did you make use of plastiguage when checking for engine clearance?
Yes everything is correct. Engine was taken apart a second time to make 100% sure again.JCTPUBLISHERS wrote:Did you make use of plastiguage when checking for engine clearance?
- J0NN0
- Moderator
- Car Make: No Name
- Car Model: Tekkies
- Membership No: 1725
Topic moved to correct section
Jonno
2002 Volkswagen Lupo 1.4TDI - SAC: 87.7 kw 276.1nm
2018 Mitsubishi Triton 2.4 D/C 4x4
2006 Mitsubishi Colt Clubcab 2800 TDI
2003 Volkswagen Lupo 1.4 16v Auto
2007 SEAT LEON FR
1983 Volkswagen Caddy - Panic: 319.7hp 360nm
2008 SEAT LEON CUPRA - Oettinger: 191kw 352nm
2008 SEAT IBIZA CUPRA - HM Auto: 146.9hp 244nm
2007 SEAT LEON FR - KAR: 163.2kw 337nm
2007 Volkswagen Polo 1.6
2001 Ford Fiesta Flite 1.4i
VWCSA Membership Number: 1725
2007 SEAT LEON FR
Sorry bearing clearance.
Tell me did you replace the oil pump and which one did you buy?
Tried an OEM pump and an aftermarket pump no difference. Pressure in the bottom of the engine going to the filter seems normal we retrofitted a gauge to test it. It must be a problem in the head or cam box. We are leaning towards cam box.missioner wrote:Tell me did you replace the oil pump and which one did you buy?
- amstel18
- Car Model: Tiguan Allspace
If you saying the bottom end has enough pressure, and the problem is in the head, perhaps a gasket issue?
I've seen issues previously caused by holes on oil ports missing on some gaskets, which results in low/ no oil flow.
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
The pressure is fine at cold start and only drops when running. We are going to get a new cam box and see if that fixes the problem.amstel18 wrote:If you saying the bottom end has enough pressure, and the problem is in the head, perhaps a gasket issue?
Good luck.
I hope it fixes the issue.
Mechanic replaced Cambox and cams which was the problem. Oil pressure is back to normal.
