VW Polo Vivo 1.4 CLP - Water Mixing Into Oil
No1ChampionStyle
Registered for: 2 years 7 months
Post by No1ChampionStyle »
Good day All
I am in need of some expert advice please. I am new on here and hoping you guys can assist. I have a Polo Vivo 1.4 CLP, the issue I am having is that I blew top gasket I think, replaced the gasket, pressure tested the head and had a light skimming done, replaced all 16 valves and valve stem seals. So after putting the head back with new head gasket the water is still mixing into the oil. Can it be that the head might be cracked or something. Please help???
Greenz
Car Model: Focus ST
Re: VW Polo Vivo 1.4 CLP - Water Mixing Into Oil
Post by Greenz »
Do a cylinder leakage test
2010 ST225 - 238kw 439nm
No1ChampionStyle
Thank you :-)
I will do that. Will let you know.
J0NN0
Registered for: 12 years 2 months
Car Make: No Name
Car Model: Tekkies
Membership No: 1725
Post by J0NN0 »
Topic moved to correct section
Jonno
2002 Volkswagen Lupo 1.4TDI - SAC: 87.7 kw 276.1nm
2018 Mitsubishi Triton 2.4 D/C 4x4
2006 Mitsubishi Colt Clubcab 2800 TDI
2003 Volkswagen Lupo 1.4 16v Auto
2007 SEAT LEON FR
1983 Volkswagen Caddy - Panic: 319.7hp 360nm
2008 SEAT LEON CUPRA - Oettinger: 191kw 352nm
2008 SEAT IBIZA CUPRA - HM Auto: 146.9hp 244nm
2007 SEAT LEON FR - KAR: 163.2kw 337nm
2007 Volkswagen Polo 1.6
2001 Ford Fiesta Flite 1.4i
VWCSA Membership Number: 1725
Dwayne073
Registered for: 1 year 1 month
Post by Dwayne073 »
I have the same problem be sure 2 check your welsh plug on the side of the head ,pressure of oil is greater then that of the water ,hence you will always find oil in your water then water in you oil when hitting top gasket or cracked head,hope this msg finds you well
UDC
Membership No: 1041
Post by UDC »
Is the oil in the engine contaminated with water or the water in the radiator contaminated with oil
