Polo gti 1.4 tfsi cth/cav engine touque setting
- Registered for: 8 years 8 months
PLEASE HELP GUYS I NEED THE TOURQUE SETTINGS FOR THIS ENGINE I'M BUSY ASSEMBLING IT AND I'M STUCK NOW. 1.4TFSI
- Car Make: SEAT
- Membership No: 478
Re: Polo gti 1.4 tfsi cth/cav engine touque setting
For which bolts / nuts?mbusongcobo94 wrote: ↑Wed Dec 23, 2020 10:29 pm PLEASE HELP GUYS I NEED THE TOURQUE SETTINGS FOR THIS ENGINE I'M BUSY ASSEMBLING IT AND I'M STUCK NOW. 1.4TFSI
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- Car Make: SEAT
CAVE, 132Kw?
Prerequisite
The pistons must not be positioned at TDC.
- Handle new gasket with extreme care. Damage will cause leakage.
- The strainer for oil circuit must be installed in cylinder head.
– Place clean cloths in cylinders so that no dirt or emery cloth particles can get in between cylinder wall and piston.
– Now carefully clean sealing surfaces of cylinder head and cylinder block. Ensure thereby that surfaces are not scored or scratched (if abrasive paper is used, grade must not be less than 100).
– Carefully remove metal particles, emery residue and cloths.
– Set No. 1 cylinder piston to top dead centre and then turn crankshaft back slightly.
– Fit new cylinder head gasket. Inscription (Part No.) must be readable.
– Fit cylinder head. When doing this, observe centring pins in cylinder block.
– Insert new cylinder head bolts and tighten hand-tight.
– Tighten cylinder head bolts in tightening sequence as follows:
10----4----2----6----8
7-----5----1----3----9
Step 1: 30Nm
Step 2: 90 degrees
Step 3: 90 degrees
Step 4: 90 degrees
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
