No spark. Need spark.. Pleeeease
- Car Model: MK1 2E Dicktator
Hi guys kindly please advise if. You can.
Vw dictator, mp9, 2e suddenly died off whilst driving.
There is no spark
During diagnosis I removed the dizzy to see if there is any response when I manually spin it.
When I spin the dizzy it only signals the fuel but doesn't spark. I'm using the coil HT lead to test for spark against ground
Any suggestions on where I can check next
It's using tp100 and a 2pin coil, they get very hot when ignition is on.
I tried to connect pin 4 (12+)of the tp100 and coil + directly to the 12v battery supply but still no spark.
I have also checked the tp100 ground and it's fine.
I rewired the three cables from the tp 100 to dizzy.
Should I. Maybe just should I just get the 3pin coil and put that in instead or maybe get another tp100 or coil?
I will greatly appreciate any input thanks. I have checked the forums for advise but I haven't found any thing else to check
There is no spark
Less noise More Speed
2l 8v
Dicktator
2l 8v
Dicktator
Re: No spark. Need spark.. Pleeeease
Just to add if it's relevant all the lights of the dictator pulse when I crank but no fire
2l 8v
Dicktator
2l 8v
Dicktator
I think you should try a 3 pin and see if it solves the problem, just give it a try
Thanks I managed to wire the 3 pin and hallelujah fire.
Is it OK to run the distributor on 12v from ignition. I think the tp100 supplies 5v to the dizzy?
My tachometer is gone how do I get it back
2l 8v
Dicktator
2l 8v
Dicktator
- Colonel
- Membership No: 1041
new spec or old spec dash cluster ?
If it is the old spec square dash, you need to buy the tacho adaptor from Dicktator and install.
Thanks guys will look for it on their website.
The 3 pin coil that I put in burned out after after driving about 200km in the rain.
My coil charge time is 2500 might this be the cause?
2l 8v
Dicktator
2l 8v
Dicktator
2l 8v
Dicktator
2l 8v
Dicktator
Reduce coil charge to 2.000ms
OK thanks will do that right away.
Just 1 last thing my ignition idles OK only when it's devided by 2.
I remember reading somewhere that it should decided by4.
Where should it be
Where should it be
2l 8v
Dicktator
2l 8v
Dicktator
It is 4 cylinder and ignition divide value of 2SupernoxV3 wrote: ↑Wed Dec 09, 2020 5:06 pm OK thanks will do that right away.
Where should it be
