Hlw guys plz help my golf 1 velocity 1.4i cranks but would not start then I tried to kickstart several times bt it didn't start then i towed it to the yard and i changed the two big fuse behind the battery now it did start nd jst cut off it start when i spray a quick start on the inlet of airfilter bt it run few seconds nd stops nd it doesn't sound like usually
What could be the problem ?
Velocity 1.4i cranks but would not start
- Registered for: 3 years 5 months
- nolan.chettiar
Re: Velocity 1.4i cranks but would not start
Check your fuel pump fuse?
Timing belt?
- Car Model: Cti
- Membership No: 2095
Had a similar issue with mine, turned out to be the Fuel Pump relay. It's located under the dash on the drivers side. There's 2 relays there, 1 for the windscreen wipers, the other for the fuel pump. Might be worth a look.
