Advise on my mk1 2.0 20valve
Sorry to just jump right in on the page but have some qs for you guys I have a mk1 golf with 2e sub and a3 1.8 20v head gt35 turbo, spiral cut stainless steel valves with double valve springs, head is port and polished, running 1.8 conrods with 83 mm pistons that is machined and pocket for valve clearance and for the perfect 10:1 compression ratio, my q is can I run 2 shots of nitrous and 1 shot of water methonal injection with my injectors and will the motor handle it or do I need to do extra work?
Re: Advise on my mk1 2.0 20valve
Need to give us more info, injector sizes, current boost, std or ARP head studs. Are you using std 1.8 conrods or I-beam or H-beam 1.8 rods? ARP rod bolts?
Injectors is the original audi injectors, I'm currently running 1.2 bar boost, H beam rods, wossner pistons, and all my bolts are ARP
- chucker02
- Car Model: Citi ADY
Stock injectors max out even with a k03s. Dont know how you are running a gt35 then
1971 VW beetle
1971 VW beetle
10:1 Cr, 1.2 bar boost plus 2 shots of Nos = Kaboom. are you running it on ethanol otherwise it definitly will detonate itself to death.
stock injector will not feed a gt35. wet shot NOS?.
Did it go Kaboom or still contemplating to do the NOS thing??
