[Hi guys
my jetta 5 2009 engine fans always stays on even when i just start up the car the fan switches on
eve after i switch the car off even if i just took it around the block the fan stays on and takes about 5min to switch off
what can this be
engine fan keeps running
Re: engine fan keeps running
Is the aircon switched on when this happens?
Is the ambient temperature quite high where you are?
Have you had the car scanned for any errors?
to answer all your question to all 3 will be no
i just got the car for literally 4 days
Have it scanned for errors and work from there.
It would help to say in what area you are in so we can advise where to go.
i live in port Elizabeth
It is your thermostat. Sounds unlikely but believe you me. I had a Golf 5 and Jetta 5 with 2.0litre engines 85kw and had the same problem with both. Occured around the 150 000km mark. I changed the thermostat after changing the coolant sensor which were relatively cheap, had the Management system reset and problem solved. Your diagnostic system will through the error code for the coolant sensor. Like I said it sounds unlikely but thats what i thought too until I have tried everything and out of pure frustration decided the replace the thermostat. Good luck.
ya got the sane car need to still take to the mechanic and see what he says
