Can carb fuel tank cause high injector duty?
- Zoltan2222
- Car Model: A3 8L 2.0L 20VT
Re: Can carb fuel tank cause high injector duty?
Roughly filed down the injector instead of trying the lathe. Curious to see how it will fit.
Sent from my LYA-L09 using Tapatalk
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
A3 8L 2.0L 20VT (project)
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
You are a very brave man to modify injectors.
- ICE King
Isn't the AGU injectors longer?
One would use a spacer when using the longer injectors but not sure how to do it the other around.
Bosch EV14 is the injector to use should this not work or keep the existing injectors and map will need to be adjusted to be milder.
The injector cups differ hence the problem.
Goodluck man
Goodluck man
- Zoltan2222
The shape of the injector indicated that the piece I filed was only plastic, the same portion of the injector was only 15mm on the other 2 sides. The AGU injectors are 16mm longer yes. For that I have asked a local engineering company to machine aluminum spacers for me, think I did upload the photos of that. So the spacer plus extra o-ring on the fuel rail, and then the filed injector should seat deeper into the cup and I hope that works, should be able to kinda confirm tonight. But the true test will only be once I get the spacers, and can actually do a remap.
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
Looking forward to see how this turns out.Zoltan2222 wrote: ↑Thu Oct 03, 2019 5:42 pm The shape of the injector indicated that the piece I filed was only plastic, the same portion of the injector was only 15mm on the other 2 sides. The AGU injectors are 16mm longer yes. For that I have asked a local engineering company to machine aluminum spacers for me, think I did upload the photos of that. So the spacer plus extra o-ring on the fuel rail, and then the filed injector should seat deeper into the cup and I hope that works, should be able to kinda confirm tonight. But the true test will only be once I get the spacers, and can actually do a remap.
- Zoltan2222
In afr we say: slim vang sy baas
So to sum that up, I should not have filed the injector all the way up to the other shoulder. Will take new measurements tomorrow as I dont have the vernier with me, but seems like the injector only needz to move in another 3mm or so.
What happened now is that the injector passed right through the cup, and as the cup is square at the bottom I could not pull it out again as the o-ring pinched. Luckily the seat was kinda loose and I could take it out to remove the o-ring and then the injector.
But I can now confirm that the 317cc injectors will seat well in the AGU cups with a small mod.
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
Oh boy, it can fit in the cups, but don't trim too much on the injector to push through the cup. did you get the distance to trim wrong to have the o ring seated inside the cup or just trimmed too much down on the two stopper parts?
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Spacers will work. But i suspect it would be easier to mod the current fuel rail mounting points on the manifold or get a fuel rail from the newer 1.8t motors.
- Zoltan2222
Okay, never thought about that, will the never fuel rail be a direct fit? As I need to drive on my current map with current injectors to Panic, and then quickly and easily change to the new injectors before remap.
So some more photos, in the first foto you can see how the current injector sits in the cup, the tip passes through the cup a bit.
My plan "planned 1" was to fit the new injector flush at the the bottom and keep the o-ring in its original position as indicated by the pencil in "planned 1".
But after seeing how far the original injector passes, I now think about doing "planned 2", making the injectors stick out more into the mani. But if I do this, I need to move the o-ring backwards as indicated by the pencil in "planned 2". The o-ring size will also be adapted to fit over that part and fit inside the cup.
Between planned 1 and planned 2, which will be better?
Will add measurements later when I get a gap.
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
- Zoltan2222
Think if I do planned 2 which seems to be the better idea, I will need to extend the cup with 5mm as well, and then need a 13mm extender at the top. If the DBW fuel rail does not fit.
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
Planned 2 will get the injector tip to a similar position as the AGU injectors by the looks of it.
Look at getting K-jet injector o rings to fit in the top groove as shown by the pencil in planned2.
Another thing to check if you go for planned 2 is to check that you still have enough clearance on the injector plug and wire loom and that it does not catch on head or manifold.
Progress update??
- Zoltan2222
Sorry, no progress as yet. Had a conference/team building weekend.
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
Ok, weekend finished. Time for updates. Will check in on regular basis to look for updates.....lol.
- Zoltan2222
Sorry, this might go very slow for a while. As the team building weekend made a huge shift in our work load/performance.
Also the lack of information on this makes it a scary road, but the local engineer is also curious so as soon as I have a gap I will stop by him with the caddy and make a plan. At least I got a E90 320i injector rail for free, and the injector mount on it might be the correct lenght to use.
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Are you ever planing to upgrade the turbo on the motor?
Reason being the 317s are near the limit on a k03s. So you might be better off grabing a bigger set of injectors of the correct length
- Zoltan2222
Well, I am going to try and stay with the K03 I have, not planning to upgrade.
I would like a set of 440cc Bosch greens like Panic also advised, but I do not want to spend that much with the small k03 in mind, but I do have these 317cc injectors allready.
My goal is to get 200whp, hopefully with the engine and turbo I have now, and also within safe reasonable limts.
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
Modifications are an endless deep money pit. Once the bug bites, you keep spending money to feed the hunger power.
- Killerwatt
- Car Make: AUDI
- Car Model: S3
On aftermarket management and a k03 you would probably get to the 180whp mark.
Max with a k03s and oem ecu is around 210whp at altitude.
If you keeping the 317s then go with plan 1. No need to have the injectors protrude too much.
Altitude is robbing us.Killerwatt wrote: ↑Tue Oct 08, 2019 2:39 pm On aftermarket management and a k03 you would probably get to the 180whp mark.
Let’s see what I will get with ko3s and aftermarket ecu.
- Zoltan2222
If 180whp is all I will see I dont know if I want to go through all the mods, that only 19hp from where I am now.
If the injector is moved back too much will it not cause the fuel to hit the intake manifold and turn the vapour back into liquid?
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Agree, if you are going throught the trouble of changing injectors for more power then rather look at bigger ones in conjunction with a larger turbo.
The 317 have an angled spray pattern so they should not hit he walls.
Dug up an old dyno for reference of a 1.8t k03s.
Don’t think there is turning back to std injectors unless the injector cups are not modified yet.
- Zoltan2222
Nope, I have not made any mods to the std stuff. Only filed that one 317cc injector.
My idea (if I continue with this) will be to make new cups and also additional fuel rail (or the extentions) so it will be possible to swop everything back if its shitty with the 317cc
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
